The last time I drove my Beta Spyder was about 4 months of months ago, when it ran without problems.
When I wanted to start it recently (with battery jump leads connected to another car which was supplying a healthy charge), it turned over happily but would not fire at all.
I replaced the plugs. Still nothing
I thought maybe the small amount of
very old petrol in the tank was the problem, so added 10 litres of fresh 98 RON, disconnected the fuel feed and pumped it through until about 300 ml was collected into a bottle. This did at least show that the fuel pump is working.
Connected it up and tried again. Nothing
Checked the spark at the end of the plug lead. Nothing!
Checked the spark coming off the coil to distributor lead. Nothing.
Does this mean that my coil has failed? Any other possible explanations?
