Author Topic: rear ARB bracket position  (Read 4800 times)
Offline lukasdeopalenica
« on: February 27, 2014, 04:02:05 PM »
Guys,
The ARB brackets (left and right side) apparantly seem to be the same, but are not. They have slightly different shape and at least different holes for u-bolts. One pair (marked in red is a bit bigger and deeper comparing to the green pair. Should the bigger openings be up or down?
Another question - is the position of the bushing inside the bracket correct? It is removed from my HPE and the picture was taken before striping it down. Haynes says the recesses should be on a vertical plane while the picture shows the same arrangement as in my removed brackets. My intuition however tells me that the horizontal position is more reasonable.
thanks for your help.
Lukas
« Last Edit: February 27, 2014, 08:06:49 PM by lukasdeopalenica »
Subaru Outback 3.0R
Re: rear ARB bracket position
« Reply #1 on: March 03, 2014, 09:56:44 AM »
really no one has changed these bushes?  :-\
Subaru Outback 3.0R
« Reply #2 on: March 03, 2014, 01:28:12 PM »
Lucas,
I have changed the bushes and I know there are two difference diameters of bush but I didn not notice any difference in the mountings
« Reply #3 on: March 04, 2014, 12:36:55 PM »
and what about the bushing position? Vertical or horizontal?
Subaru Outback 3.0R
« Reply #4 on: March 04, 2014, 07:38:35 PM »
I genuinely can't remember  - sorry
« Reply #5 on: March 10, 2014, 08:30:21 AM »
OK, I will leave it as was
Subaru Outback 3.0R
