Author Topic: Silverstone and Thanks  (Read 3078 times)
Offline alcarr
« on: April 29, 2014, 08:26:37 PM »
I think I have missed the boat for club display at Silverstone this year, but I would still like to attend with the Spyder, does anyone know a good B&B or guesthouse that would be suitable. And again I would like to thank you all for your input regarding the oil leak. The mechanic at Richard Thorne believes that a breather pipe had a split in it which may have well caused it, I can't pick it up until Friday due to the industrial action on the tubes, it is all hand to the pumps as I can get into work, so hopefully they can run it again and confirm that it is problem solved.
Regards Alan
Re: Silverstone and Thanks
« Reply #1 on: April 30, 2014, 07:26:48 AM »
If you are in the LMC I'm pretty sure that there will be room for you in their grouping if you get the car back.
