Author Topic: behr thomson engine thermostat  (Read 21352 times)
Offline Tone
Re: behr thomson engine thermostat
« Reply #20 on: April 29, 2015, 11:40:58 AM »
I decided to fit a 75deg "in head stat" and adjust the pipework accordingly.  The only problem I have noticed after fitting is, the temp sensors for the L-Jetronic are now on the cold side of the thermostat during the heat up period, meaning the fuel trimming for warm up is out of whack...but is barely noticeable and after three miles is back to normal operation.
3-4 mm hole in the stat will solve the problem. I also made this modification on my 2000i.e.
Offline gengis
« Reply #21 on: April 29, 2015, 09:34:53 PM »
I have now covered 700miles since drilling the by-pass hole, and the temp rises to a steady 1/4 scale rising to half way in heavy stop/start traffic...result!
1983 - Lancia Beta Coupe
1982 - Fiat 124 Spider
2012 - Alfa Romeo Mito
2011 - Fiat Fiorino
2006 - BMW F800st
