Hi all,
I've had my project Beta Coupe for a year now and it's time to get to work on restoring her.
The engine turns over fine, but won't fire. I have no spark at the plugs, which appears to be the obvious issue.
Last night I started to undertake some diagnostics and upon testing the voltage at the coil with the ignition on, the most I could get was 0.5V. I have another coil, so swapped it over and exactly the same - 0.5V.
This is an electronic ignition Beta. Any ideas where to start next or where the issue may lie?
Thanks in advance
Terry
