Author Topic: Solution for front wishbone bushes  (Read 25589 times)
Offline Per
Re: Solution for front wishbone bushes
« Reply #20 on: November 16, 2019, 09:31:02 PM »
I have just replaced the bushes in mine with OEM pattern bushes from ebay Italy. Perfect fit and all is well. Had to fabricate pullers to extract the old ones and pull the new ones in.
« Reply #21 on: November 18, 2019, 07:25:02 AM »
I'd be interested to see a photo of the puller you made up. I've heard of people having to burn the bushings out.
Offline Per
« Reply #22 on: November 25, 2019, 08:00:07 PM »
Extracting:
The narrow ring fits where the bushing protudes into the vee, NB! I inverted it in the picture!!!
The large cylinder allows the wide outside end of the bushing to come into the cylinder without being pulled out of kilter and jamming in the wishbone.
« Last Edit: November 25, 2019, 08:03:18 PM by Per »
Offline Per
« Reply #23 on: November 25, 2019, 08:06:22 PM »
Inserting:
The short cylinder to the right sits outside the vee and fits onto the larger end of the bushing.
« Last Edit: November 25, 2019, 08:17:44 PM by Per »
Offline Per
Steering wheel puller
« Reply #24 on: November 25, 2019, 08:21:35 PM »
And while I am at it, here is the very simple steering wheel puller I made. The two bolts fit in the steering wheel boss into ready made threaded holes made for the purpose.
