Author Topic: Drive belt tensioning  (Read 4833 times)
Offline abgwin
« on: September 15, 2014, 02:18:51 AM »
Just replaced my timng belt and now putting the drive belts back in place.
Can not figure out how you're supposed to tension the 'middle' belt that drives power steering.
I got the alternator/water pump ('top') belt and the air conditioner compressor ('bottom') belt tensioned about right but I can not figure out how to take out the slack in the power steering.
In the photo, you can see the bottom A/C bracket and the power steering adjustment nut (I think it's also the pivot stud for the A/C bracket). I can pry up on the adjustment flange but it just doesn't move enough - it needs to slide to the adjuster's end. Or is that how it's done?
Suggestions appreciated!
Re: Drive belt tensioning
« Reply #1 on: September 15, 2014, 12:29:21 PM »
Not familiar with ac cars on this side of the pond of I get chance I will check of I have any info but lancisti is probably your best bet for an answer
Offline lukasdeopalenica
« Reply #2 on: September 16, 2014, 07:50:25 AM »
I always tension the belt in such a way that the belt bends between the two pulleys about 1cm under my finger. To increase the tension I use a lever placed between the alternator and engine. This should be fine also in your case with AC compressor..
Subaru Outback 3.0R
Offline abgwin
« Reply #3 on: September 19, 2014, 07:36:46 PM »
Turns out that the power steering pump has a vertical rod to control the tension. A square nut on top moves it until the lower adjustment stud/nut can be secured.
Yes, you can use a lever to move the A/C compressor and tension it, but the power steering has a different mechanism. Not sure if this only applies to later model with A/C; perhaps if there's no A/C there's no need for the vertical rod, as you can get a lever on it directly.
Sure wish my shop manual had late model info in it!
