Author Topic: Has anyone rebuilt the fan motor?  (Read 3802 times)
Offline dougdee123
« on: December 12, 2014, 02:11:43 PM »
Hi All,
As the title suggests I'm wondering about rebuilding the heater fan motor. Does anyone know if that is even possible?
At the moment if I turn on the fan (slow or fast) the ignition light glows. Whilst recognising that a popular reason for that might be that the diode pack in the alternator is partially damaged  I am wondering the motor may be drawing more current. I see that the headlights etc don't cause the same glow.
This is likely to be part of the programme of work in the merry festive freezing garage.
Doug
Re: Has anyone rebuilt the fan motor?
« Reply #1 on: December 12, 2014, 02:56:17 PM »
when  you turn anything remotely electrical on in a Beta I find there is a strong chance the ignition light will glow dimly, is it just that or worse?  When I had a (flavia) 2000HF I had these issues and found that it was due to earthing problems on the instrument panel
« Reply #2 on: December 13, 2014, 08:40:21 AM »
I'd check what is actually going on with a multimeter before pulling the motor out. I wouldn't have thought that the motor is particularly easy to rebuild?
