Hi all,
I am a proud owner of a VX coupe and have just read your thread regarding listing them all.
Thought id just let you know she is still with us.
Her Reg is B190 VCX, have owned her since Oct 2009 but had been unable to get her back on the road until now.
She goes in for an mot tomorrow ( tue 7/7/2015 ) after having new outer sill, loads of rust removed and repaired on inner sill,
welding to the square locating plate for the assembly line.
New discs and pads allround, couple of new brake pipes, set of new tyres and a clean out of the carb.
Previous works have been carb rebuild, new cam belt and tensioner and a couple of oil leaks fixed.
She has 79,000 miles on the clock and is in ok condition, will hopefully be able to use her at long last for the remainder of the summer.
Plan to get a bit done each year, ( other outer sill and inner sill etc ) as the wallet permits.
Hope this helps your list.
Regards
Lee
