Resurrection of old thread alert... but for a good reason...
If you've read this far (and various other threads) you'll know that I've been laboriously putting together a hybrid 2000 i.e./carb engine to replace the one that was wrecked by an incompetent mechanic in France. The original engine was removed from the car in April 2016 and brought back to the UK for repair/renovation. On the same trip I took down a 2000 i.e. engine converted to run with carburettor, and the process of swapping them over started. We visited the house (and the car...) again in July 2016 and by the time we left I'd managed to get the replacement engine bolted into the chassis, but with all the refitting of drive shafts, exhaust, cooling system etc. still to do.
I went back down again in Oct/Nov 2016 (observing the 1st anniversary of the calamity) and by the time I left had the engine fully plumbed in with the exception of some minor exhaust work. I just simply ran out of time (a common refrain).
I'm back down at the house again now, and am pleased to report that the exhaust is fully fitted, and the engine is definitely a runner!
I'd gone through all the usual pre-checks (spinning the engine over without plugs, refitting plugs & leads and priming the pump with the rubber fuel bulb) and was ready to try it out on the starter. However I had somehow omitted to notice that the throttle linkage was still tucked away in the scuttle instead of connected to the cambox and carb. Oh how we laughed...
With that resolved I gave it another turn of the key, more in hope than expectation I have to say, and blow me if it didn't start with the first turn of the key! I nearly crapped myself with surprise... I really wasn't expecting that, as I'd only set the ignition timing 'by eye' and was fully expecting to have to do battle with that before it would run.
So only about 18 months after the engine locked up at the hands of the French garage owner, it's now a runner again. I've still got plenty of things to check out and fix, but at least I was able to take it for a short bimble around the village.
Onwards and upwards...
