I'm not sure if this should be under this section or under the specific areas, but here goes . this weekend we attended the Classic Weekend at Silverstone. It was our intention to go via the M25everything was fine until we got near for the exits to M3 and M4,thats when things went wrong. We were in the car park that is the M25 the car was ticking over fine then nothing it just died, the weather was warm and the engine was hot but not overheating. It would not restart and we were in the third lane unable to move a call was made to the RAC plus the Motorway Service the next half hour was very scary until the traffic was halted and we were pushed over to the hard shoulder.
The car would not start we had a spark and fuel coming through but when the air cleaner was taken off the float chamber was dry then after priming the car started and ticked over fine. We continued on to Silverstone.
We turned up at the event and was ready to park up, but reverse could not be engaged and we were pushed back, to finish off the window on the passenger side refused to wind up the handle just slipped, after taking off the door card we got the window up manually.
So I have a few questions, would the carburettor be sticking or was the problem heat, the problem with the reverse seems to be the oil getting hot and gear engagement being lost I would appreciate a recommendation for a good make of oil for this plus a good engine oil my local spares shop is stocking Comma oil specifically for 1970s engines.
If the winding mechanism needs replacing are they available?
Lastly I noticed the spark plug cables were carbon filled, would it be a recommendation to replace these
