Author Topic: Failure of axle splined joint.on series 1 coupe.  (Read 4840 times)
Offline betasulo
« on: September 13, 2016, 07:44:04 PM »
Dear All,
I have just had another axle splined joint fail rather prematurely. Does anyone know the cause of this and any  permernant modification to correct it.
Re: Failure of axle splined joint.on series 1 coupe.
« Reply #1 on: September 17, 2016, 09:33:04 PM »
I'd not heard of a spline failing.
Is this inner or outer and on which side?
Each spline is mated to the cv joint with a round circlip which gives a 'lock' effect,i.e. to stop
excessive lateral movement. The only lateral movement is generated by the limits of the suspension travel.
Which,under normal road use, is very slight indeed.
Offline betasulo
« Reply #2 on: September 22, 2016, 06:16:17 PM »
Hi Nigel,
This is a cylindrical part which the axle slides into and you are correct excessive suspension travel may cause it to drill its way through the splines. Just wondering if any one else has had a similar problem!
Regards
Sulo
Offline betaveloce
  • Country: be
« Reply #3 on: September 23, 2016, 10:09:45 AM »
My uncle had several HPE's in the eighties/nineties. His last one was a 2.0 i.e. and that particular car also suffered this problem. I remember the garage changed the part the first time, but after a few months he had the same problem again and then the garage decided to weld it to the driveshaft... but that did not last long either. Finally he gave up on the car  :( The reason why this kept happening, was never found...  :-\
Beta Spider 1.6 '80
Beta HPE 2.0 i.e. '82
