Author Topic: Alternator bracket  (Read 7038 times)
Offline jreacock
Alternator bracket
« on: November 23, 2016, 11:06:47 AM »
Hi all. Hoping someone can help me with this one. I've been renovating my 81 Spyder for a while now, and even though I thought I'd taken plenty of pics when disassembling, I don't have one showing the alternator bracket bush positioning. I bagged and labelled all the bits, so I'm fairly sure that everything I took off has been put back.
The problem I have, is the gap between the alternator bracket and the fixing bracket. It looks like something is missing, but I can't find out what it is. There's another post about the bushes and fixings for the alternator, and I seem to have all of the parts shown in the photo in the post. The left side has two half length bushes that push in from either side, and the right side bush is full length and pushes in from one side.
Any advice is much appreciated.
Cheers,
Justin.
69 Fulvia 1.6HF S1
71 Works Fulvia 1.6HF
75 Gp4 Stratos HF
81 Beta Spyder 2.0
82 037 Rally stradale
Re: Alternator bracket
« Reply #1 on: November 23, 2016, 05:33:05 PM »
Hi Justin
The only difference between yours and mine is the distance of the two fixing posts on the alternator, mine fits snugly with all the parts you have, so suspect the alternator is not an original spec, but after market one which has different mounting gap. You will need to improvise a spacer I would guess?
Offline jreacock
« Reply #2 on: November 24, 2016, 12:25:49 PM »
Hi Peter. I pretty sure that the one I have is original. It also matches the one that came with a donor HPE that I broke down years ago - which also has the same selection of fixings. I wondered whether the same part was missing from both to be honest - but it seemed a bit unlikely.
A pic of the one end of the alternator before I cleaned it up - not sure if you can identify it from that.
And a pic of it attached. Not a great pic - but the engine is still on the stand, so I can take a better one.
« Last Edit: November 24, 2016, 12:28:05 PM by jreacock »
69 Fulvia 1.6HF S1
75 Gp4 Stratos HF
81 Beta Spyder 2.0
Offline jreacock
« Reply #3 on: November 24, 2016, 04:41:31 PM »
Here's a closer shot of the unit:
69 Fulvia 1.6HF S1
75 Gp4 Stratos HF
81 Beta Spyder 2.0
« Reply #4 on: November 25, 2016, 12:23:30 PM »
Here is a shot of my setup
Offline jreacock
« Reply #5 on: November 25, 2016, 02:39:43 PM »
Thanks for that Peter. Interesting.
69 Fulvia 1.6HF S1
75 Gp4 Stratos HF
81 Beta Spyder 2.0
Offline Pee Vee
« Reply #6 on: June 21, 2020, 11:33:50 AM »
I realize the thread is old, but it could help someone going forward to see the original poster's picture.
I believe the one piece bush presses in from in between the legs. Justin just needed to flip it around.
