Well, here we are again - one step forward, two steps back.
Yesterday I completed a task I hadn't been looking forward to - manhandling the component parts of a 2 ton engine hoist up from the cellar, reassembling them and using said hoist to lift the engine out of the Mk. II dolly. I needed to do this so I could rout a 30mm x 12mm wide groove in one wall of the frame so that it would clear the non-OE sump plug I'm using. This dispenses with the internal taper thread OE plug and uses a 'standard' external hex head sump plug with copper washer. I've always found the OE Lancia sump plug a painful piece of work, with the internal hex head prone to rounding off.
So a while back I converted the taper thread to parallel by use of the appropriate tap, but had omitted to make allowance for the extra projection when designing the Mk II dolly. I rectified this oversight using my DeWalt palm router, reassembled that part of the dolly, dropped the engine back into the dolly, then dismantled the engine hoist and returned it to its resting place in the cellar.
Nest step was to remove the placeholding bolts on the clutch to flywheel fixing and replace them with 12.9 cap head screws and Schnorr washers, torqued up to 24 Nm, and with a dab of blue Loctite applied for good measure. So far so good.
Then I turned my attention to the back water rail, which was similarly just held in place rather than finally tightened up. I'd planned a belt and braces approach on the water pump to back rail interface, using a combination of a fibre gasket I'd made up, Wurth assembly paste and an o-ring of a suitable size. Everything was lined up, partially tightened and then finally tightened to 24 Nm. All except the top water pump stud/nut, which wasn't coming up to torque, and was starting to feel 'wrong'. That was the point at which I should have stopped and taken stock. Except I didn't and wound up with a sheared stud.
So now the water pump has to come off and have the stud drilled out, an exercise that always fills me with deep joy... And before I can get the pump off, I have to remove the pulley which (from past experience) I know will need an impact gun. And the impact gun is in Sheffield and the engine is in Stafford.
Bugger.
