Hi Graham
I think you are fooling yourself!!!!
Thread started in 2016 and you will soon look at the rest of the car and think, maybe I should tidy up the car to match the engine?
Another 5 years go by……..
Only joking, hope you get it in the car this year and start enjoying it.
It doesn't help that the car is in France and I (and the engine) am in the UK. In 2015 I was intending to bring the car back to the UK to start refurbishment. I'd booked the ferry crossings and we were about 3 days away from coming back when the water pump started squealing its head off. Instead of replacing it myself I panicked and put it into the local garage in our village. Bad mistake.
Long story short, he completely f***ed the engine, bending 7 out of 8 valves when he decided to replace a cam belt which had only been replaced less than 1000 miles previously (see photo below). Fortunately my neighbour in France was able to retrieve the car and put it in my garage while we were back in the UK. Then I had to do an engine swap, bring the original engine back to the UK and start refurbishing it. Since then the car has only run intermittently on its donor engine, so I still haven't been able to repatriate the car.
And then of course Covid happened, further complicating matters. And so I'm now in something of a dilemma. The engine/gearbox is very close to being ready to go back into the car. But I would much prefer to install the engine in the car in the UK where I Have a far better support network. I also want to get the carburation/timing etc. set up on a rolling road before the engine has many miles on it, and that also would best be done in the UK. So taking the refurbished engine to France and doing an engine swap there is not the best option.
But I don't have a garage in the UK. I've made tentative enquiries near me but have so far drawn a blank. I also need to be sure that the car is sufficiently reliable on its donor engine to make the 800-odd miles back to Sheffield without breaking down.
And you're right - there are a fair number of things I need/want to do to the car while the engine is out, which also needs a garage. So for the moment I'm just getting my head down and trying to ensure the engine/gearbox are as good as they can be and await an opportunity to bring the car back to the UK and get stuck in to all that needs doing.
