Author Topic: Early model HPE heater core/ac unit removal  (Read 3830 times)
Offline mwredit
« on: January 02, 2017, 08:17:22 PM »
I'm attempting to remove the heater/ac unit in my '77 HPE to replace the heater core.  I've removed the 4 upper attaching nuts under the cowl, the heater hoses and ac lines.  I can only get the unit to drop and wiggle 1/2".  It seems as though there's another bolt or two holding it up, but unable to see through all the wiring, glovebox, etc.  I've consulted the factory service manual and the very vague Haynes manual to no avail.  I've scoured the firewall for extra bolts, etc and found nothing that would hold this unit in.  On most US made cars, you have to remove the whole dashboard to replace the heater core.  I hope I dont have to do this here.  What am I overlooking here?  Any suggestions?
Thanks,
Mike
Mike R.
1968 Mercury Cougar XR7
1961 MG Midget
1974 Ford Mustang II Ghia
1977 Lancia Beta HPE
Re: Early model HPE heater core/ac unit removal
« Reply #1 on: January 02, 2017, 09:27:59 PM »
It's a long while since I've done this but I've got the feeling the dash has to come out  - the good news is it's a pretty simple job.
Offline mwredit
« Reply #2 on: January 03, 2017, 04:33:13 AM »
Update...The heater/ac unit is now out.  The back of the unit was stuck to the firewall insulation, which is coated with a tar-like substance and hardened with age.  I gave a little more force than I did the last time with a tug from the back, then the front and with a slight twist.  That did it.
Mike R.
1961 MG Midget
