Took the HPE to get it smogged this morning. Well, to my disappointment, it failed due to high CO readings (measured 2.75, Max is 1.46, normal .17). Everything else was low, like the NOx was below average and the HC was slightly above average. It seems like the carb is running too rich. The smog guy said to junk the car (I DONT think so, it's rust free!) and didnt seem too knowledgeable about carbs. It has a 32 DATRA 12 Weber. I rebuilt this carb a few months back with a new carb kit and float. Perhaps the float level is too high? If it had a power valve, I would suspect that. I cant imagine it being more than the float setting. It has been spatting at the mid revs once in a while, the few times I've been driving it. This car passed smog two years ago and everything passed then.
Thoughts?
Thanks,
Mike
