Poll
i am currently rebuilding a vx coupe and need to get some oil for the supercharger. can anyone help me locate some. thanks
oil
0 (0%)
oil
0 (0%)
Total Members Voted: 0
Author Topic: vx supercharger oil  (Read 12294 times)
Offline blazer_one
vx supercharger oil
« on: June 04, 2009, 08:40:43 PM »
hi folks
i've been a lancia nutter for years and have had betas and spiders.
i am just getting back on the road a 84 beta coupe vx and was wondering if anyone knows where i can get the oil for the supercharger from and as i took the the oil out do you need to prime before use and if so how.
thanks in advance
Simon from Carlisle
1984 beta coupe vx and 1981 monte spyder
Offline hutch6610
Re: vx supercharger oil
« Reply #1 on: June 05, 2009, 01:54:03 AM »
The supercharger uses ZC90 oil - from Fiat.
Or you can go to a car spares shop and get something like 75W 90, 80W-90 - 1 litre should do it.
Never run it low or without oil as the front bearings if damaged are £300.00 from Mr Croft and the gears you cant get!
Blower will be scrap.
You fill the blower by pouring it into the reservoir and allow it to to settle in its own time, you will have to fill and do this a number of times, oil level is correct when its in line with the seam on the reservoir.
If you are impatient like i am i would suck on the top breather pipe (i am disgusting like that) this draws down the oil quicker and cuts down the waiting time - do three loads and give it 15 minutes to see what happens, repeat until it full.
You wont get oil in your mouth by the way.
Check the level every 300 miles or you are at the mercy of old Crofty!!!!!!
Offline blazer_one
« Reply #2 on: June 05, 2009, 07:23:44 AM »
thanks very much for your help.
this weekend will be the firing up of the old girl!
regards simon
Simon from Carlisle
Offline hutch6610
« Reply #3 on: June 07, 2009, 07:48:11 PM »
Don't forget to pack the rear bearings with grease while your at it.
Offline blazer_one
« Reply #4 on: June 08, 2009, 08:10:29 PM »
opps
did'nt get this note in time but guess what it starts and runs takes oil and the blower is quiet so i'm hoping that will sort it.
only problem is it has no tickover and miss fires a bit.
i was resigning myself to the fact i was going to have to take it to a tuners so sort but if you have any ideas it would be GREAT.
thanks simon
Simon from Carlisle
Offline hutch6610
« Reply #5 on: June 09, 2009, 06:02:15 PM »
Strange having to do this again.
Read the following;
http://www.lanciabeta.co.uk/forum/index.php?topic=348.0
Try this and see how you get on - any problems just post back.
Offline Lanciacharlie
« Reply #6 on: June 09, 2009, 09:30:12 PM »
Just looking at the bearings in the picture and the tubes shown are there any grease nipples you can fill them with grease instead of a strip down ! thanks Paul
Offline hutch6610
« Reply #7 on: June 10, 2009, 12:02:17 AM »
Unfortunately the only way to get grease in is to remove the small access cover - four 10mm nuts and just pack in the grease with your finger, also pack the outer cover, bolt on and wipe clean.
You dont have to remove the back completely as i have, this photo was posted to see if i could upload  it - thanks again to Matt.
Tubes you see are for the breather/ scavenge system.
« Reply #8 on: June 10, 2009, 07:35:16 PM »
Soory to be silly but is this with the blower in situ.   Thanks Again   Paul
Offline hutch6610
« Reply #9 on: June 10, 2009, 10:09:38 PM »
Yes you can pack the bearings without removing or dismantling the blower.
And no your not being silly!
« Reply #10 on: November 28, 2025, 10:09:20 PM »
Resurrecting this thread is there a definitive answer to the oil specification that goes in the reservoir of a VX supercharger? Thanks
« Reply #11 on: November 29, 2025, 08:10:04 AM »
In the back of my mind I recall using Tutela ZC90 - It came in a tubular can but it may have been gearbox oil, my memory isn't as good as I'd like!
« Reply #12 on: November 29, 2025, 09:05:54 AM »
Thats my recollection but is there a today equivelent? EP90?
« Reply #13 on: November 29, 2025, 10:47:33 AM »
eBay.it lists a Tutela ZC90 under the brand name Petronas.
https://www.ebay.co.uk/itm/126841632158?_skw=petronas+80w90&itmmeta=01KB7K6QV43T5D0RBJ2P9Y0RSQ&hash=item1d8859b59e:g:O5gAAOSw651nWrHN&itmprp=enc%3AAQAKAAAA0FkggFvd1GGDu0w3yXCmi1cNVPPnSlarjhihJ2o1NLDr4wk5ZbUwcFbTOZPteOS2Q%2FZg%2Fv%2FLptyBZVeIhuOvvjHhIXIDUW3ZTDG4bEKJ3cx0X5MwyObzNrPmCU65fq9BZeZnOBZbuB7B7d%2FMaXS3uEdZz4CbvI486HO8X7IXs7jB%2Fo7VpE56IjW5MzQGA3%2Foy%2FuNVfTA%2BcdPQs9SZJhJW5I4suKsHQaJhibJkbpmbONLRD4pCdt%2FKbOH5J3RrE3WL1MoAYq5PTUtHZoIPdtxke0%3D%7Ctkp%3ABk9SR_j9mvPZZg
But it's a tad expensive. it's an 80W-90 transmission fluid.
This comes up on the search as the same animal (and a little cheaper) described as MTF300
https://www.ebay.co.uk/itm/267459585907?_skw=petronas+zc+90&itmmeta=01KB7K0404910KQQ2AH6VZ7KD9&hash=item3e45d56773:g:0YYAAOSwJ1RnPviu&itmprp=enc%3AAQAKAAAA0FkggFvd1GGDu0w3yXCmi1c9q2nmKcihJA9UV%2FGu2n0JEVaBm%2BA9LkaA3RCW0GtoRlTZcEgQFjTkYa5YcuQeXdgl0uRbDFXa0QfZ%2BIYIkQ49zQTJgvQUg2DC5xRQbnrdN2BIHxmwe0Ea36yJPM2W%2BWixslao2ft%2B%2F6ZUpppzUL5ZIOD4wL%2BMStF9dAt3NhZDiZ4o7Rd88KKBXH4LkvJbAzxDamxyNwzsuf4zWyjYKkKJb%2BjAtDnj0HMWcRhIVwd1RIGMU7qUlUkfK%2BO2mgb5rUc%3D%7Ctkp%3ABk9SR6zAgPPZZg
And Opie Oils have one left at a much more realistic price..
https://www.ebay.co.uk/itm/165410890758?_skw=Petronas+MTF300&itmmeta=01KB7KHWTQPWFCEP4AM6REZN33&hash=item268341e406:g:TUQAAOSwjFFlnvP0&itmprp=enc%3AAQAKAAAA0FkggFvd1GGDu0w3yXCmi1dhw%2FLZaAoG27AUxwEaSAD6ZkgGPHe9qEq62KiBNEADtV6giinTZhXnLh5pgGgUbFBiO944ucex6G09XKnjM4A7571Tunh2Dl5Dbpy8BlY0zutA8Bi1i%2FywrRL0buqfO62PO1PLtC51jjZdJw%2F%2BFxcwVXu7%2Brubmfxc4BtKp%2BgW55cv1HmCGS31MaKiOtIStJi67y8YmqVHEbgx4s9SpDr5yq0W9u2QNd18G1LZujY%2Bq0AaKSRM1Snd5tR0%2FiRsI8I%3D%7Ctkp%3ABk9SR87Nx_PZZg
« Reply #14 on: November 29, 2025, 09:28:14 PM »
If you want it Tanc Barrat sells the real mcoy
