Author Topic: Suspension bushes  (Read 11331 times)
thecolonel
Suspension bushes
« on: July 13, 2009, 06:35:06 PM »
Yes, Yes, I know it's not the write section, but everyone reads "General Discussion" so
does anyone have the oe part numbers for Beta front and rear suspension bushes.
reason being  the Gamma runs a very similar setup and if the numbers relate it's
another outlet for parts.
Geoff
rossocorsa
Re: Suspension bushes
« Reply #1 on: July 14, 2009, 11:22:18 PM »
you are daft enough to think that gammas would use the same parts wasn't the car made by Italians??...seriously when I have the time I'll check for you got gamma and beta books and fiches
thecolonel
« Reply #2 on: July 14, 2009, 11:30:04 PM »
Thanks appreciate it, (certainly got the same rear end..... ooo-errr) ;-})
Geoff
rossocorsa
« Reply #3 on: July 15, 2009, 11:00:42 AM »
I've quickly checked series one gamma against an early series two beta parts books it would appear that there are no common parts however this doesn't necessarily mean none will fit Lancia changed part numbers like the wind on the beta often each series or sub-series will have differing part numbers/ slightly different parts ...the joys of Italian motoring!!
thecolonel
« Reply #4 on: July 15, 2009, 12:54:56 PM »
Thanks,
I had thought that
silentblock 82323112 (front wishbone)
silentblock 82320406 (rear transverse link)
silentblock 82320238 (rear cross-member)
silentblock 82315794 (rear arb/hub)
arb bracket 82317097
might have been the same, purely on the "they all look alike to me" scenario
Geoff
rossocorsa
« Reply #5 on: July 15, 2009, 01:05:10 PM »
82320406 does seem the same but it seems to be the bush for PRESSED type arms on a beta which is a bit odd
rossocorsa
« Reply #6 on: July 15, 2009, 01:08:13 PM »
82315794 is the same
rossocorsa
« Reply #7 on: July 15, 2009, 01:09:38 PM »
that seems to be it  it was easier to check from your list all those parts lists make me cross eyed!!!
thecolonel
« Reply #8 on: July 15, 2009, 05:54:01 PM »
Thanks, at least I can start sorting out replacement poly bushes.
Geoff
rossocorsa
« Reply #9 on: July 15, 2009, 11:56:18 PM »
bit unsure about the one that fits pressed arms on a beta wouldn't surprise me if the polybush version wouldn't fit a gamma as the shape of the polybushes are different
