Author Topic: Heater inlet flap  (Read 4848 times)
Offline jwhelan
Heater inlet flap
« on: October 07, 2018, 01:12:27 PM »
Hi folks,
   Is it possible to adjust the heater inlet flap movement (84 HPE)?  Mine doesn't close by quite some margin, and the lever doesn't move more than about 60% of the way across.  Hopefully the answer doesn't involve removing the heater!
    Thanks,
         Jay
Re: Heater inlet flap
« Reply #1 on: October 13, 2018, 12:36:44 PM »
I think the cable is secured to the dashboard levers with a crude plastic clamp using a self tapping screw. If you take the radio out and remove the surround, then shine a mirror on the back of the levers you should be able to see if the cable has slipped through the clamp.  If you need to adjust it, then I think you can unscrew the lever set and pull them forward to do so.
