Four weeks on from the first proper testing and there have been a few things to fettle:
The toe-out of the front wheels has come out a bit to 3mm which feels a lot better.
Next, with the Betaboyz shorter springs, I fitted Betaboyz supplied Spax top-adjustable shock-absorbers on the rear using a mid setting; this has proved too hard... it felt like the car was on the 'stops! Adjusting them to fully soft has done the trick for now but i'm keen to hear others' views?
The carbs were finally properly jetted by Mark Hardy at AutoMark last week and the difference is significant; the Beta had been a bit of a pig to drive 'discretely' at low revs when moving around town but lots of jets-swapping on the rollers has done the trick. It's way smoother and the dyno graph proves Guy's forecast of lovely flat(ish) Tq from 2500rpm across to 8000rpm (peaking at around 200Nm at 5200rpm) and a max power of around 180bhp at 7600rpm. I know the dyno print can be just a bit of reassurance but it was nice to see!
Finally, I'm having a few snags with the OE starter motor. It was reconditioned before re-fitting, and all the feeding electrics and switching have been checked, but it sometimes struggles to turn the engine... particularly after a few priming pumps on the throttle. It seems better to just turn the key then give some throttle once the engine's spinning so maybe the higher engine compression is the problem. Anyhow, I'd really welcome any thoughts before I commit to trying a high tq unit.
