Author Topic: Cam belt tensioner bearing identification  (Read 4005 times)
« on: January 26, 2020, 01:00:55 PM »
Hi all,
A very old thread on here identified this:
http://uk.rs-online.com/web/p/ball-bearings/2851692/
This cam belt tensioner bearing is listed as
25mm internal diameter
52mm external diameter
20.6mm width
Where as mine,just removed, is
24.9mm internal
51.83mm external
20.5mm width
Will this fit? Am I being pedantic? Are these normal tolerances?
Thanks in advance
Re: Cam belt tensioner bearing identification
« Reply #1 on: January 26, 2020, 01:18:54 PM »
Hi Nigel
So long as it fits on the the spindle ok, then the outer dimensions will be fine as the tensioner will adjust to the belt I think you will find the belt tolerances are somewhat larger....
« Reply #2 on: January 26, 2020, 01:32:53 PM »
Hi Nigel
Peter,
This is just the bearing,not the whole pulley. So its got to fit within the housing.
« Reply #3 on: January 26, 2020, 02:11:08 PM »
Hi Nigel
Sorry, I was thinking of the Saab one I recently replaced. Guess the only way to know is to try fitting it if that is practical. I noticed for the wheel bearings that there are two slightly different od sizes listed on specs of bearings I have for the rear ones I am replacing, the difference is 0.2mm, I guess it all depends what tolerance was originally designed in.
« Reply #4 on: January 26, 2020, 11:44:12 PM »
I imagine they are the same, the reason I chose that particular bearing spec is partly lost in the random memory of my becoming senile mind but I think I recall it was too do with designed rotation speed and the fact that it has a plastic cage so will fail in a less catastrophic manner giving some kind of warning of failure prior to seizure, plus of course SKF are always very good.
« Reply #5 on: January 27, 2020, 09:27:35 AM »
Every bearing/retainer interface I've come across has been a snug push fit; i.e. no need to get the bearing pressed into the housing. It doesn't exactly 'drop in' but doesn't put up too much of a fight. It's a tight enough fit that pressure on the outer of the housing causes the bearing to spin, rather than the bearing to spin in the housing, if you know what I mean. This assumes that all parts are clean, rust free and lightly lubricated (not the outer part of the housing that contacts the belt, obviously) when assembled.
The only time I'd be concerned is if the bearing is a sloppy fit in the housing. If you buy the one-piece part of course this area of concern is obviated.
« Reply #6 on: January 27, 2020, 05:31:39 PM »
Most single piece ones available now are the wrong size for 2 litre cars though
« Reply #7 on: January 27, 2020, 06:39:59 PM »
The bearing came out with a large socket as a spacer using a small bench vice. Not tight but not loose either.
That fits your description exactly.Thanks!
The only difference is that the old bearing has 2 internal races,I don't think that matters.
I've ordered from RS,should get it tomorrow.
Cheers all, N.
« Reply #8 on: January 27, 2020, 07:04:13 PM »
If the bearing you’ve ordered is the same number as on the outside of the old bearing seals, then it will be exactly right.  Single/double race, Size, plastic or metal cage, running clearance etc etc. It’s all in the numbers on the side. The designations for seal type and internal cage differ from one manufacturer to another but it’s very easy to cross reference online.
You’ll normally find bearings are cheaper to order by number rather than application. Unless you find some old stock being off loaded.
Sorry if you already knew this.
