Author Topic: After market alloy wheels, clearance for spacer and disc retaining bolts  (Read 4329 times)
As above what are members solutions for the above when the recess on the inner side of the wheel isn't quite large enough? Removing a small amount of the alloy has been suggested which I can do but I would really prefer to keep the wheels in standard condition. I suppose that the wheel bolts will keep the disc etc located but I'd rather that these were securely located if I have the wheel off.
I used Cap head bolts with Snor serrated lock washers no wider than the bolt head and that fitted in the wheel recess. When I use spacers I have countersunk fixing bolts so there is no bolt on the surface to interfere with the wheel. BTW I also have rolled arches at the rear.
PS the factory track is wider at the front than the rear for performance reasons. They made it less for the later cars.
I hope this helps.
Thanks, I'm not sure that a cap head will give enough clearance on the Ronal wheels that I have (I had a look earlier) I should clarify that when I say spacer I mean the standard 5mm ones that go on the front.
