Author Topic: Cambelt Tool Fixture 88013039  (Read 2900 times)
Offline DaveFrick
« on: September 02, 2020, 11:30:18 PM »
I just acquired an 81 Beta Zagato 2.0 FI.  The mileage is 91,000 miles and the prior owner has never done a timing belt.  I think it needs to be done upon acquisition to create a baseline.
I scored a US Factory workshop manual from Ebay.  It shows the cambelt change in and out of car.  I will be doing it in car.  The recommend the factory fixture 88013039 to align the key timing points- crank/auxilary/cams.  Checking Youtube for the Lambredi 4 cylinder DOHC build and using a Fiat motor as an example; the builder lines up the cams easily to the points top of engine, sets the crank at approximately 2 o'clock, and sets the aux pulley using two points to create an imaginary line with the mark centered.  I suspect this is how the Haynes manual presents it.  However it seems not as precise as it should be.
So the question(s);
A cambelt change should occur? and
Assuming so, does anyone have the factory tool for sale or is there an aftermarket tool that would work as a substitute?
Thanks in advance,
Dave
Re: Cambelt Tool Fixture 88013039
« Reply #1 on: September 02, 2020, 11:52:19 PM »
Hi Dave
You do not need the tool. Many of us have done it without it. See here as an example and there is a video listed at end of the thread.
https://www.lanciabeta.co.uk/forum/index.php?topic=2146.0
« Last Edit: December 12, 2025, 02:26:39 PM by peteracs »
