Author Topic: My HPE....now a rolling recommission  (Read 198918 times)
« Reply #360 on: October 15, 2026, 10:21:56 PM »
I did Mark, but I'm cheap and couldn't justify 500 squids or thereabouts.
The spacers came from precision autoparts via ebay, however any search
for hubcentric spacers for a Fiat 500 will give results.
I think the rear looks better with the added track, but bear in mind that the factory
designed it like that for better road behaviour although simple me doesn't notice.
More important is the quest for decent wheel bolts. I complained bitterly to precision
about the bolts they supplied with the spacers. They were wobbly when screwed loose
into the hub, i.e. the threads were poorly cut, I did not use them, and got
a partial refund. They continued to refuse to acknowledge the bad bolts, even saying it was me
being daft! (That may be true, but not about bad threads)
So, I ordered 8 bolts from trs-uk, and the difference was outstanding,
these having a nice solid fit with virtually no sideways movement.
Whatever size spacers you choose (mine are 15mm), you must increase
the length of the bolt to ensure you have, as a minimum, 12mm threading
into the hub, and preferably slightly more.
Rightly or not I use anti-seize grease
on all my wheel bolts and this will give you a witness mark when sizing.
A small downside is that you'll probably have to accept a smaller hex on the bolts.
Luckily, I have a reversable socket with 17 and 19, extremely useful.
Perhaps
at some point I'll change the front bolts to match.
« Last Edit: October 15, 2026, 10:29:07 PM by Nigel »
« Reply #361 on: October 15, 2026, 10:58:28 PM »
I didnt notice the difference front to back until you mentioned it.  Thanks for the info Nigel
Offline lancialulu
« Reply #362 on: October 16, 2026, 08:15:49 AM »
I would be concerned using spacers that did not replicate the hub spigot. The spigot it there to centralise the wheel and without it the wheel will move around and loosen the bolts. Not something to worry about for a show car but I would not use them if wanting to use the car in anger. Just my 5p worth….
« Reply #363 on: October 16, 2026, 10:29:25 AM »
I think most replicate the spigot.  It dont think it would last two minutes without.
I worked for a local builder near Bath in my youth.  I was driving his old transit van with a trailer loaded with the moist stuff you render pebble-dash walls with, very overloaded.  On Keynsham High Street I felt a big jolt and a wheel went past me at speed, where he had done exactly what you warned about.  I unhooked the trailer, put his business card on the top and ran  :)
« Reply #364 on: October 17, 2026, 06:02:04 PM »
You probably missed my comment about using hub-centric spacers Tim!
It's important to use these.
Offline lancialulu
« Reply #365 on: October 17, 2026, 06:16:50 PM »
Didin't know what that meant so went old school in describing what should be used! As a matter of interest are all hub centric spigots the sam o/d as Beta wheel i/d?
« Reply #366 on: October 17, 2026, 10:35:23 PM »
Don't know about all Tim, but
if searching for 'hub-centric Fiat 500', those fit Betas in
my experience.
Offline stableblock
« Reply #367 on: October 18, 2026, 06:30:02 AM »
There are lots of options of hub size.  The spacers arent universal.
« Reply #368 on: October 22, 2026, 05:25:55 PM »
Back to the alternator:
The new belt arrived next day and fitted perfectly.
On with the 2 belts and new alt, tensioned both, then attempted to fit
the brace, to find that it fouled.
I relieved it as necessary, then welded in an 8mm round bar as extra support.
It's back to rigid.
Fired her up this afternoon and found it charging at 14.8 volts, as per the
tech sheet. Happy with that. The highest I ever saw with the previous alt was 14.3v.
The old issue remains, the dash charge lamp is still glowing very faintly, not surprised,
I'm sure that's a wiring/earth issue.
The next dry day is Sunday according to the latest reports, so
hopefully I'll get a chance to drive, and then retest the charging after the run.
« Reply #369 on: November 29, 2026, 03:18:27 PM »
In preparation of a forthcoming strut brace I completed some
necessary tasks today.
I've fitted longer studs in the top shock mounts and lowered the
ignition module about an inch.
It appears the coolant reservoir cap will likely foul, that will wait.
Also, barely visible, is the negative jump-start post which will be difficult to
reach. I may well delete these jump posts. It seemed a
good idea at the time but they're really not required, as I go direct to battery normally.
The top of the steel pipe looks like the highest point/space
available for the brace.
« Reply #370 on: November 29, 2026, 05:03:16 PM »
Is there room to move it nearer the bulkhead Nigel?
« Reply #371 on: November 29, 2026, 06:25:38 PM »
Guy,
When I fitted it I made a flat bracket as a simple solution as it didn't
matter exactly how it was positioned.
I reckon I've got somewhere between 50-70mm space behind the
tank, and I think I can maintain the height, which I'd rather not change.
It's a nice task for next weekend.
