Author Topic: Identify function of gearbox plug  (Read 3342 times)
« on: July 03, 2021, 02:26:27 PM »
I noticed for the first time this plug, which in appearance and position
looks like a filler point, but it's far too high to be a level indicator.
I have always filled via the dipstick hole, but perhaps
this is a filler?
Re: Identify function of gearbox plug
« Reply #1 on: July 03, 2021, 04:43:51 PM »
Hi Nigel
When you re-build a box this is removed to insert a lozenge that locates the shift levers. It is made of incredibly soft aluminum making it scary to remove and re-fit.
« Reply #2 on: July 03, 2021, 05:09:49 PM »
Thanks Eric.
So, if I understand correctly, it's access to a gallery behind the lever shafts,
used to keep them in position?
« Reply #3 on: July 03, 2021, 06:42:30 PM »
Hi Nigel
I refer you to the Haynes Manual gearbox re-build section and you will understand. The Haynes Beta Manual is actually helpful for a gearbox build.
