Author Topic: Wheel Alignment settings  (Read 6642 times)
« on: August 07, 2021, 08:44:19 PM »
Good day
I've got the Haynes and the Lancia figures which agree on the Rear at 2-5mm toe-in.
They conflict on the front however: Haynes says 1-2.5mm toe-out
                                                     Lancia says 1-2.5mm toe-in
However I read somewhere on here that there is new
thinking/ better settings recommended these days.
Pointers gratefully received!
Offline betabuoy
  • Chris Mace
Re: Wheel Alignment settings
« Reply #1 on: August 07, 2021, 09:25:33 PM »
Hi Nigel
I think there’s a degree of personal preference when setting tracking. IIRC, I’m using about 3-degrees toe-out which works for me.
Chris
1967 Morris Minor Traveller
1925 Austin 7 Chummy
1948 Piper Cub Vagabond
« Reply #2 on: August 07, 2021, 10:56:53 PM »
Hi Nigel
There was also a comment on here I seem to remember, but not able to find it, from someone who uses toe in on his race car as it makes it handle better for him. So as Chris says, down to personal preference. I used Haynes figures to set mine up and did not realise the Lancia ones were different.
« Reply #3 on: August 08, 2021, 01:54:19 PM »
These are the most recent information from Lancia on this, from the final technical data book issued in 1984 and two technical bulletins '83 and '86
https://www.amazon.co.uk/photos/share/pBeYcYCHhmYuuUezoXDGlTVixdd0XOCYWCS3IWzD7zh
Make of them what you will, as always when you dig things can get confusing
« Reply #4 on: August 08, 2021, 02:10:46 PM »
Here's a different view from a very early technical data book. (1974)
In this I believe the figures are for a loaded car.
https://www.amazon.co.uk/photos/share/YBIm3hlhQzqAhwfViN6AMIWCft1PGGt2rqFi3MUYhj4
Offline capriblu
« Reply #5 on: August 08, 2021, 04:40:59 PM »
As I read these Lancia data sheets then toe in recommended for rear between 2&5mm and for the front anywhere between 1mm toe in and 2.5mm toe out.  i.e. negative number refers to toe out .....
« Reply #6 on: August 22, 2021, 12:10:00 PM »
I would go with the latest settings because they will get closer to modern tyre needs. I have custom settings I will try when the car is complete, but I have adjustments not present on standard cars.
PS be aware wheel spacing is staggered on these cars from the factory (different front to rear). So keep wheel spacer size consistent front and rear if changing wheels.
« Reply #7 on: August 22, 2021, 12:47:17 PM »
Hi Eric,
Are you suggesting to maintain the factory wheel track spacing front and rear?
Is that a design feature to improve dynamics?
« Last Edit: August 22, 2021, 04:16:37 PM by Nigel »
« Reply #8 on: August 22, 2021, 04:37:27 PM »
Hi Nigel
Yes I am and yes it is. More often found on more expensive cars. I came across this when working through my wheel and tyre check last year. At first I thought the data books had typos so I googled it.
« Reply #9 on: August 22, 2021, 06:21:40 PM »
I used to run the front with toe-in on my Beta race car because it turned into a bend sharper especially when trailing the brakes. In mid corner it also drifted into understeer more progressively and when pushed deep into understeer it comes back quicker. I never got on with front toe-out. More understeer and slower to return grip.  Both my VX coupe on coilovers and my Berlina run toe-in.
Golden rule on the rear, ‘always run toe in’ or you will have the back coming round on you every time you lift off of the throttle in a turn or even braking slightly on a roundabout. Toe out on the rear is for the brave or the insane. Track use only!
Then move the tyre pressures a few psi and you can change it all up again.
Of course we all drive differently and prefer different responses, so experiment until you find what suits you.
« Reply #10 on: June 03, 2026, 06:28:53 PM »
Hi Nigel
Chris
Going to get my tracking checked tomorrow.  I have tried front toe-in and now out (by accident) and I think I like it.  I am guessing 3d isnt much?  I will take the doc Alan added here.
I have a feeling next winter I will fit some of Mark's new springs if he does a second batch, and would love some Spax gas shocks on the front to match the rear
« Last Edit: June 04, 2026, 12:19:36 PM by Ferrit »
Offline lancialulu
« Reply #11 on: June 04, 2026, 10:19:33 AM »
Unless a race car it is normal for front wheel drive cars to be toe out (1-3mm measured on the rim) and toe in at the rear......
« Reply #12 on: June 04, 2026, 10:22:59 AM »
You are forgetting that Lancias aren't normal 😂....I suspect fine tuning is a matter of trial and error.
« Reply #13 on: June 04, 2026, 11:21:28 AM »
As mentioned before I used toe in rear and toe out front and have zero complaints on handling so happy to leave as is. Maybe the difference is subtle and in general not a big difference under normal road use?
« Reply #14 on: June 04, 2026, 12:20:41 PM »
amended my rushed post above.  Correction toe-OUT front and toe-in rear  :P
« Reply #15 on: June 07, 2026, 11:40:06 PM »
I was thinking of trying to dial in 2mm out at the front and 2mm in at the back.  Whilst I know the attachment settings are wrong it does feel a lot better.  Assuming because that are all similar now?
Question is, do I just measure myself the required toe-out/in mm or does anyone have the right degrees/minutes settings for my garage fitters, I am sending myself around the twist trying to convert this.  They said figure it out and come back.
Using a converter calculator and a wheel and tyre diameter of 615mm, I am thinking in minutes its -50 and +50 front and back total for the axle respectively, any thoughts would be massively appreciated?
« Reply #16 on: June 08, 2026, 09:04:44 AM »
Hi Mark
Hope this helps.
I used triangle calculator
https://www.calculator.net/triangle-calculator.html
I input one side as 356mm (14 inches) and next as 1 mm with 90 degrees between them and result was 9' 39", ie 9 minutes 39 seconds, for 2mm result was 19' 19".
Obviously if your sizes differ then re input to get result.
Offline lancialulu
« Reply #17 on: June 08, 2026, 12:40:49 PM »
Hi Mark
Hope this helps.
I use two strings down side of car and a steel rule>>>>>
« Reply #18 on: June 08, 2026, 02:47:57 PM »
I think I am going to look at this as you say 'just measuring it' and see how I get on.  Getting all setting mostly equal each side is a good starting point.  I will give it a try.
« Reply #19 on: June 08, 2026, 03:02:00 PM »
This is also my method and has worked well on the Spider for me. The modern laser setup does have the advantage of also checking camber and castor which although fixed can show up if you have any accident damage etc and if wildly out which could cause difficult to diagnose handling issues.
