My hpe had fairly poor headlights, rusty reflectors and a foggy beam pattern. I acquired another set last
year but these weren't much better, and the MOT test flagged them lousy.
After some research, I knew I could fit complete new units with bowls etc, but the adjustment would not
be so accessible.
So last week I ordered a pair of standard Lucas lamps. Then the fun started.
I stripped out the Siem lamp down to what I needed: removed the chrome ring, removed the glass,
[breaking it out pretty much the only way], and cut out the lamp holder.
I then centered the new lamp with the ring, marked out and drilled 3 x 5mm holes in the rim, and made them into
slots with a file. Then 3 more holes at 4mm just above the slots. Once the primer and
paint had dried, I then cable-tied the lamp to the ring. The chrome ring fits well, but can't
be tabbed over like the original method, so several spots of CT1 secures it.
The end result, at present, is ok, but the lamp does protrude forwards about 10mm.
I think I can set it back with some mods to the backplate, more to come on that.
