Author Topic: Early HPE restoration  (Read 121572 times)
0 Members and 5 Guests are viewing this topic.
Re: Early HPE restoration
« Reply #440 on: April 21, 2026, 08:18:43 AM »
Might that job be one you could delegate to a paintless dent removal body guy?  Unless you really know what you're doing it might end in tears? I guess finding a replacement will not be easy these days.
« Reply #441 on: April 21, 2026, 10:51:55 AM »
An interesting option. I will see who is local.
Here is a photo of both the attic (dump room) and parts polished so far!
Petet
« Reply #442 on: April 21, 2026, 12:22:22 PM »
Been there and done that Peter! Still got a few scratches but it's acceptable for me!
« Reply #443 on: May 29, 2026, 02:26:41 PM »
So away in France and up popped on Ebay a new badge for the front grill at a seller in Italy. All the badges I have are pretty grim and will not come back regardless of how much polishing etc I give them. So pressed the button and 3 days later it arrived, really pleased with it and no taxes!
Offline deks
  • Steve Hudson
« Reply #444 on: May 29, 2026, 02:35:33 PM »
Petet
Ive got a guy from Grantham due to me today for pointless dent removal. I will ask him while he is here if he can deal with the chrome trims. I have his details if you want them for any ventless work.
« Reply #445 on: May 29, 2026, 03:23:18 PM »
Hi Steve
Thanks.
FYI the trims are all Stainless, no chrome involved.
Offline deks
  • Steve Hudson
« Reply #446 on: May 29, 2026, 05:37:19 PM »
Hi Steve
Thanks.
I asked him while he was here. He said no it's not possible. His words were you'll have to buy new so I pointed out that isnt possible with these cars. I think because it's not a fixed panel he can get behind he cant push the dent out.
« Reply #447 on: July 04, 2026, 11:05:18 PM »
Not a lot of progress as been out in France and some illness at home has meant I get limited time to do anything to the car. However managed a few hours recently and managed to address the main door glass where the glass is not too bad thankfully as probably difficult to find (plain glass), but the metal support had some rust showing. So I decided to rub it down, apply the rust treatment/primer and applied a coat of a zinc based paint to hopefully keep in decent condition. (Photo below)
I also manage do sort out the final stainless parts and started polishing it. One of the final parts I had been trying to find are a pair of external door window scraper trim. Most of these appear to separate the scraper from the main trim piece. I nearly bought a pair from a late HPE VX, but decided they were no better than the pair from the donor Coupe. Once cleaned up I need to attach the scraper to the main trim piece, some comments have suggested using bonding compound such as Sikaflex works, so will be giving that a go. Note these external scrapers are different to the original pre facelift ones and in my view are a better design to keep water out of the internals of the door.
« Reply #448 on: July 10, 2026, 10:15:39 AM »
New toy arrived at 6:30 this morning, driver was glad to get it off the van…..
I decided to get this for the HPE as the dolly it is on at present just gets in the way of replacing all sorts and this should give me better access.
Eric, I took your comments onboard re weight and yes really heavy, so when finished with the rebuild may consider moving it on, though tempting to leave collapsed in place under car as will make lifting it so much easier than with trolley jacks.
One comment I will say is that I will be using multiple axle stands as wel, no chance on relying solely on this whilst I am under it!
« Reply #449 on: July 11, 2026, 12:04:15 AM »
I will look forward to seeing it under the car
« Reply #450 on: July 11, 2026, 09:59:33 AM »
Hi Peter Good Luck and mind your back and toes moving it around. I think for your semi permanent under the car use it will do the job. It gets old quickly if you have to push roll the car over it when collapsed often.
« Reply #451 on: July 11, 2026, 07:39:22 PM »
Hi Eric
Yes, probably not something I will hang on to after it has fulfilled its immediate use, just do not have the space.
