Author Topic: Early HPE restoration  (Read 128863 times)
0 Members and 6 Guests are viewing this topic.
Re: Early HPE restoration
« Reply #460 on: August 08, 2026, 09:04:35 AM »
Not a bad idea Nigel. I think I would change the Diff Bearings and seals, Clutch arm bush, Main shaft output seals behind Clutch release bearing and of course an oil change and quick inspection with the end plate removed on the main box. Note the bolts for the cover plate respect plenty of release agent maybe heat to prevent snapping. I replace mine with Stainless bolts as they carry no significant load. With the box in service if 1st to 2nd Syncro is OK then a second oil change with the box hot soon after using it to get the crud washed out. Beware the box with golden oil on top and black sludge below. This is oil breakdown and it etches the Syncros and trashes all the bearings. I saw this on a 24k only Monte Box that then needed all new internals.
Offline Carlwil10
« Reply #461 on: August 08, 2026, 05:16:50 PM »
Great to meet you peter and thanks very much for the roof trim for my beta.
Carl
« Reply #462 on: August 08, 2026, 08:55:42 PM »
Hi Carl
No problem, hope it fits the early car? Looking forward to your next installment!
Hi Eric/Nigel
Good call on the diff bearings, I have a new set of seals already. I do intend to drain the oil and see if there is any residual sludge. The first box I bought was supposed to be refurbished, but not by the seller, so it will be suck it and see time.
Thanks for the comments
« Reply #463 on: August 08, 2026, 08:58:00 PM »
Also just received a pair of new door keys from John Richard. He managed to source some new/old stock blanks with plastic ends rather than the solid metal ones. Fortunately the code on the end of the glovebox lock is the correct one for the rest of the car. The only key I had before this was an after market and had no markings.
« Reply #464 on: August 08, 2026, 09:42:38 PM »
You added some very good points Eric. I was perhaps
a little brief on my post!
Those diff bearings are easy to get and easy to fit, and don't
affect any existing pre-load set-up, provided the shims all
stay in place.
« Reply #465 on: August 24, 2026, 11:38:40 PM »
After using the new tilting lift on the Spider, which did a good job. I now wanted to use it on the HPE shell to allow me to get rid of the current support 'dolly'. The problem with using it as intended is that the bars which connect the two sides of it would get in yhenway of the dolly. So I split into two separate lifts and arranged them under the sills of the shell. Each has a separate gearbox so this worked well. The only issue being having to support the bars which stick out. I then connected a drill to take up the slack
The shell is now supported by the tilting lift both sides. I will see how it progresses probably leaving it for more elderly folk. I will make some more permanent supports rather than the blocks of wood I grabbed to keep it balanced.
« Reply #466 on: August 25, 2026, 08:24:33 AM »
That is probably a design improvement given the weight. I guess getting both sides rising to the same height involves running round the car though.
« Reply #467 on: August 25, 2026, 10:23:16 AM »
Hi Eric
Yes you have to raise each side so care needed there, also to use regularly will involve some improvement to sideways stabilisation, but the benefit is weight/maneouverability and storage all of which are a problem when you want to move it. Also this way together with axle stands for added security leaves the center of the car without any obstacles whilst under the car. Also only one side has the retaining pin to stop the tilt so that one needs to be used if only using one of them to access a particular side.
« Reply #468 on: August 30, 2026, 04:39:01 PM »
A decision which has been kicking around unanswered for a long time was what fusebox to use. After discussions with Philip Day (Thema/Dedra Consortium) at The Restoration Show a year and half ago, he kindly sent me over time a couple of Thema fuseboxes and some of the special housings for the spade connectors. Apparently there is more than one version of this fusebox shown in the first and second photo and the special connector housings vary!
I opened one up to understand the construction and it uses multiple layers of flexible PCBs, so no corroding wiring etc internally which is a great result. I therefore set to sorting out the pin outs etc which is no mean task, gleaning info from a Thema 8.32 wiring diagram. After going a fair way down this route I decided that having a new fusebox was probably a good way to go, but drew a blank other than one in Lithuania with a seller not happy to ship to the UK.
At about this time I stumbled upon a very similar fusebox used in an Iveco truck (third photo), which is the same construction, but more relay slots, a little bit bigger, but should fit in the passenger footwell and they are available new from various UK sources at reasonable money. So order has gone I for one of them. The bonus is that the internal wiring diagram is available as a download (I did not find an equivalent for the Thema one).
Also originally having a shortfall of the correct connectors for the Thema box, I set to and produced a 3D print copy of the housing which has two advantages, the originals use a spade connector which is slightly unusual, so I designed the new one to accept standard spade terminals and I can tweak to keyways to suit whatever slot I want to use it in.
A fair amount of time and work to get to where I am with it, but I now feel happy with my choice which should give me plenty of capacity both fuses and relays.
« Reply #469 on: August 30, 2026, 05:11:04 PM »
A wise choice Peter. You probably recall our discussion at your Betameeta a couple of years ago; the passenger footwell works very well, as does the Durite item I used.
For reliability and safety, the rewire, modern fuse box, and relocation away from the exhaust manifold, was the best decision I made with my Beta.
« Last Edit: August 30, 2026, 05:17:16 PM by betabuoy »
« Reply #470 on: August 30, 2026, 05:32:52 PM »
Hi Chris
Yes, remember looking in your car and talking about it. I also have some of those generic relay and fuse boxes in case I run out of places on this box, unlikely on the fuse end, but maybe on the relay. One thing I like about the Iveco box is it has a stud for the 12V input rather than a simple connector.
« Reply #471 on: August 30, 2026, 11:10:56 PM »
Chris that fusebox tray, did you have it made, it looks very cool.
« Reply #472 on: August 31, 2026, 09:07:52 AM »
Just for fun here is the Fusebox interconnect.......
Will take a while to sort out the wiring.
« Reply #473 on: August 31, 2026, 01:44:58 PM »
[/quote]
[/quote]
Hi Mark, Yes this was made specifically to hold the relay and fuse blocks and fit snugly at the back of the pax footwell; it has a simple cover then carpet folds over. It is less accessible than the original site, but I’ve not needed to visit it in the last 5years!
« Reply #474 on: August 31, 2026, 04:36:12 PM »
Paid a visit to John who restored the HPE body today.
After giving a Lincoln wheel restoration company my wheels a couple of years ago and them coming back in a pretty crap state and a pretty boring silver grey colour, I had talked with John about them and agreed he would have a go at stripping and repainting them, this time with a metallic silver rather than a flat colour. He also had the original honeycomb grill which we had to do some plastic repairs to and agreed to go with the same colour on it.
So after what must be a year and a half, he had finally done the job (no rush I said of course!).
Results are excellent, really happy with the colour and finish on all items, so that is another part put to bed. Photo of the grill includes the new badge I managed to source from Italy.
« Last Edit: August 31, 2026, 09:02:19 PM by peteracs »
Offline Clifford
« Reply #475 on: August 31, 2026, 05:43:14 PM »
Look lovely Peter.
« Reply #476 on: Today at 06:20:07 AM »
Looking amazing. This is heading for Concours winning.
