I wasn't sure whether to add this post to my engine rebuild thread in Members Cars or start a fresh thread in this section. As it may assist other owners, and seeing as the question logically belongs here, here is where it is...
I'm gearing up (see what I did there?) to re-fit my overhauled gearbox to my refurbished engine and I'm on the look out for hints and tips on general practice but specifically how to reattach the thin pressed metal parts that sit between engine and gearbox. I'm aware of two pieces - an upper and a lower. As far as I can see the upper piece (larger and more complex of the two) has to be fitted (or at least offered up) prior to flywheel and clutch installation. The lower (smaller) piece looks as if it needs to be fitted during the course of the gearbox and bell housing being bolted up to the engine. There are four M6 holes in the lower piece that enable fixing to the lower part of the bell housing. The photo below should indicate the parts I'm referring to.
My question is this - is the lower piece fixed to the bell housing before, during or after the gearbox is mated to the engine? I'm also interested to know how folks approach this operation. Do you elevate the gearbox using an engine hoist and slowly manoeuvre it into position, or are other methods employed?
Thanks in advance for all suggestions and responses.
