Author Topic: Quick Alternator wiring question (black and white wires)  (Read 2374 times)
Offline Modano
« on: February 09, 2022, 07:22:23 PM »
I usually take pictures before dismantling anything but the pictures are not clear enough to take the risk.
On my coupe , there are three black and white wires that plug to the alternator.
TWo are much thicker , one thick is bolted below and the other thick was bolted above (b+).
Problem is that there is a smaller black and white and I m not 100% sure that it plugs along the big one.
The below bolt was not removed and I didn’t remove any other bolt but I don’t want to take any risk.
Do you confirm that both wires are bolted on the bolt above ?
See pictures :)
On One of the pictures, I put them along on the same bolt. Seems obvious but once again, not taking any risks. Electrical diagrams are not really helping as all the ones I found seem to differ connection count wise.
Offline jreacock
Re: Quick Alternator wiring question (black and white wires)
« Reply #1 on: February 09, 2022, 08:51:42 PM »
Hi.
I'm attaching a pic of my alternator in case it helps you.
69 Fulvia 1.6HF S1
71 Works Fulvia 1.6HF
75 Gp4 Stratos HF
81 Beta Spyder 2.0
82 037 Rally stradale
Offline Modano
« Reply #2 on: February 09, 2022, 09:08:41 PM »
Much appreciated :)
So before I saw your pic I checked the following:
- upper big black  and white seem to go to fuse box (and is not at doubt)
- smaller one joins the big green positive from battery on the starter
- Lower big black and white it earthed
So , and your pic seem to confirm, the smaller one which go to the starter is connected to the B+  ?
