Morning all, inlet manifold off car so taking opportunity to clean some stuff up, buy new pipes and so on.
One thread here suggested cleaning out the ventilation valve. There's a 13mm nut that releases a cover where the pipe from crank case enters and pipe to airbox exits. I was expecting something inside the cover, something like wire mesh or a filter.
There is a bit of wire mesh wedged in pipe near air filter, but I can't see the point of this "cover" otherwise
Any ideas?
