Author Topic: Anyone got one of these?  (Read 3689 times)
« on: August 10, 2022, 10:30:24 AM »
If it is indeed a 'thing' - the support/connection between the brake pipes and the front strut. - haven't got close enough to see how it is fixed yet. Completely absent on the other side of the car, just the bracket.
Re: Anyone got one of these?
« Reply #1 on: August 10, 2022, 11:30:15 AM »
Probably missing because the 6x1 bolt snapped off in the hole! so best check. If so cable ties will work if you are not good at removing sheared bolts.
« Reply #2 on: August 10, 2022, 02:14:12 PM »
Hi Mark
When you say absent do you mean the removable bracket with the bolt through it?
« Reply #3 on: August 10, 2022, 06:25:47 PM »
Peter and Eric- thanks, you are both right, sort of.
Bolt has gone, possibly partially in hole tbc, but unbelievably, the plate I have, having found it on the drive years ago and put it the 'I wonder what that fell off' box!
