Author Topic: Factory holes in front floor of Spyder  (Read 1803 times)
Offline Clifford
« on: August 22, 2022, 09:24:38 PM »
I have my passenger seat out for a tidy up and cleaning of the runners and checking the floor and tidying things up makes sense as the seat's out.
There is what appears to be a hole made by the factory but its missing the seal. There may also be a second one close by, but that is sealed.
Does anyone know why the hole is part of the design and whether there was a metal bung in there or a rubber grommet originally?
Anyone else filled this hole and what solution did you come up with?
C
Re: Factory holes in front floor of Spyder
« Reply #1 on: August 24, 2022, 01:08:39 PM »
The large and small holes have been there on all the beta floors I've seen. The larger one is blanked by a steel bung, the smaller one by a rubber one. There's similar in the rear floor.
As to what they were for I don't know but I've put them back in on mine when replacing the floor!
Offline Clifford
« Reply #2 on: August 24, 2022, 04:17:51 PM »
Cheers Stuart.
Do you know what size rubber bumf it is? Did you just use a blind grommet?
C
« Reply #3 on: August 28, 2022, 07:43:39 AM »
I don't know what size the small ones were exactly as I redid them with the nearest size tank cutter I had to hand (20mm) but yes a blind rubber grommet and plenty of seam sealer.
Offline Clifford
« Reply #4 on: August 28, 2022, 08:01:06 AM »
Many thanks Stuart
I think they may well be 20 mm.
C
