Today was an expensive one. All heating and cooling related with an awful lot of searching interwebs.
Andrea left me alone today and went for a walk, she hates being in the house when there are workmen in and today it was the boiler being changed. There is more noise to come as the cupboard needs surgery before it will go back in place and can I find the bloody jigsaw.....
So, internet research and the use of a measuring stick in the last couple of days in the interests of filling the void that is the hole where the radiator lives. Measured at 660mm wide and 350mm tall from the top surface of the crossmember to the underside of the engine steady bracket plus a little wiggle room and a day searching for something suitable that should keep the engine cool, oil temperatures low and the interior nice and cold when needed and I've ended up with the following solutions, now winging their way to the front door ready for further modification!
First off is the radiator itself, I went for a ready made custom one that's got a core that't 360*300*70 (four rows) with overall dimensions of 465*310*70. The original Beta core is 470*320*40 so the extra rows should give more cooling area. Time will tell! It'll have mounting lugs for fans, inlet and outlet on the left side and a vent pipe for the expansion tank already built in. It should also have fan mounting lugs on the front.
https://www.ebay.co.uk/itm/405423437366?mkevt=1&mkpid=0&emsid=e11400.m144671.l197929&mkcid=7&ch=osgood&euid=72ff2ad4b886493ab36373c2fbd8d4ae&bu=43153383004&exe=0&ext=0&osub=-1%7E1&crd=20251015063729&segname=11400Next is the oil cooler, I went with a Setrab one, not the cheapest option but the engine deserves it! It's 330 tall and 146 wide (installed vertically) with a set of mounting bobbins adding about 30mm to it's width makes a radiator pack width of (465+146+30) 641mm and by the time I've got ducting at the sides sorted and mounts top and bottom made I think that will fill the hole nicely.
https://www.t7design.co.uk/setrab-series-6-235mm-19-row-oil-cooler-black-50-619-7612.htmlLastly there is the air conditioning radiator and I've gone with one from T7 Designs (one stop shop for most of the installation except the compressor and evaporator I hope) that measures 593*350 and looks to be a perfect fit. Again, Time will tell. I think I'll be able to use the front fan mounting lugs on the radiator to secure one side and the bracketry I need to fabricate for the oil cooler for the other side.
https://www.t7design.co.uk/ac-condenser-radiator-593-x-350mm-30311346cp.htmlAs for mounting this radiator pack I may be able to suspend it from the underside or back face of the top slam panel and support it using two existing brackets on the front of the crossmember which would be ideal as it would give more space behind to utilise for the carburetors and air box (to be designed) and also an Accusump.
Needless to say there are still more components bought (driers/trinary switch and brackets plus oil cooler unions and bulkhead adaptors) and much more to buy (pipework, unions and fill valves) but it all needed to be sorted now to allow me to more other parts along!
