Yesterday I dragged the neatly rolled up loom into the dining room where there's lots and lots of room. I decided to identify the cables that run from the brain to the back of the car, basically the lighting harness plus fuel pump, courtesy light, heated rear window and anything else I could find. It was a nightmare of tangled cabling by the time I'd got 7 or 8 separated and zip tied together. Plus the majority of them have been supplied way over length as they will also do front lighting circuitry too once chopped and spliced in.
I realised that this method wasn't going to work. At all. So, after a good night's sleep (not) and two veranda salesmen here today I went to the local timber store and came back with a piece of 8ft*4ft MDF (on the roof of the Skoda - surprised it didn't fit inside!) and a bit of 2*2. There was also a fair bit of timber frame left over from a double bed we'd binned earlier this year so at 4pm I started sawing, measuring, bolting and screwing together an easel to take the weight of the MDF. Tomorrow, if I get the chance, I'll be sorting out some lighting and some fixings to secure the loom to the board and then measure the various runs I'll need with rope to transfer this to the board. A few more nails to hang spare loops of wire and a couple of lengths attached to a battery with a test light to confirm pins/wire ends and I think I'll be in a better place to build the loom outside the car, labelled, ready to install easily.
Famous last words.
Think I've earned a chippy dinner tonight.
