Author Topic: And So It Begins....  (Read 186351 times)
Re: And So It Begins....
« Reply #880 on: August 09, 2026, 05:54:55 PM »
No, there's aircon in the car don'tcha know!
Might not be working yet though.... :)
« Reply #881 on: August 10, 2026, 04:06:00 PM »
Thanks Stuart, no rush yet, still plodding through circuitry and struggling with some! I'll look into the Magajolt one though!
Hopefully the meds are taking effect....
In any case the coil mount was indeed made for me by Jason Miller and his company Millers Mule back in 2011 when he did quite a few Fiat T/C and Alfa parts. He also did my alloy crank pulley with trigger wheel. They're good items but I should note he did me for $50 extra and then refused to answer any mails.  It looks as though he's still about doing 3D printing with a different company.  You could always message him and ask for the drawings if he's not making them any more.
« Reply #882 on: August 13, 2026, 04:54:59 PM »
You learn something every day. Or in my case, often relearn something you forgot.... But this was a new one!
I took the Panda 100HP for its MOT yesterday (another clean pass - phew) and discussed LED lighting with the examiners I've dealt with for years and years. Apparently, if you have changeover LED sidelight/indicators the light sequence must be white changes to orange as you start indicating to off to orange to off to orange to off to white when you stop indicating. No switching back to white mid flash. That's a new one to me but it makes sense. I look forward to finding out if my front indicators are MOT compliant before the  test!
Had a delivery of wiring today plus some other bits and bobs so I may get back to that tomorrow and over the weekend if it's cool enough in the garage!
« Reply #883 on: August 14, 2026, 04:51:08 PM »
Not quite the day I anticipated with wiring today! After the Panda passed its MOT I thought I'd better sort out a couple of points the examiner noted but didn't record as advisories! A slightly discoloured front indicator bulb (very easy swap) and a pinhole in the expansion tank. That too was an easy task with one screw and two clips (if you've got the Clik-R pliers). That lot got swapped over easily enough and I even saved the antifreeze in the old tank with a little careful maneuvering!
Then a visitor to the house for a pre-planned appointment and this afternoon back to fitting terminals to the instrument cluster connectors. Normally I hate spliced or joined wires. They're a weak spot and I prefer to keep connectors to a minimum. However, in this case, given the fragility of the circuit board on the back of the panel and the weakness in the edge connectors I made the decision to put three multiplugs into this part of the loom. There are 22 wires on the three blocks so I used a 6 terminal connector block and two eight connector ones (with the male/female plugs reversed on the second one so an idiot like me can't misconnect them in future). The new blocks are numbered so I just wired them in order of the gauge plugs from left to right or top to bottom. Should make mating them to the main loom much easier later on. Protection from a few lengths of cable tubing and we'll call that a job finished. There's one warning light not connected, the gearbox one. I can live without that!
« Reply #884 on: August 14, 2026, 05:46:15 PM »
Gearbox warning light -explainer please
« Last Edit: August 14, 2026, 07:04:23 PM by peteracs »
« Reply #885 on: August 14, 2026, 06:20:20 PM »
The speedometer I'm using has a warning light for the gearbox. What aspect it warns you about I have no idea. I guess I could wire it up to something else but unless there's a sender on the box for something I don't know about it'll remain unused. Maybe it's for an automatic gearbox warning? If anyone can shed any light on it please shout out!!
