Author Topic: door key number  (Read 73440 times)
tonylanciabeta
door key number
« on: November 04, 2008, 09:40:26 PM »
Hi I have just bought a coupe that is for restoration.
It has the ignition key but not the door/glovebox/fuel flap key.
Does any one know if there is a way of telling the key reference from the locks or anywhere else?
thanks
spydervx
On the latching cam of the glove box door you will find a 4 digit number. This is the door key cut code. Hopefully it is the original cam. Being plastic are prone to breakage.
Hi stablemaster1
Thanks for the info. Yes I have checked and the only lock missing is the glovebox! I dont know if the code appears on any other locks will check them and see.
Thanks for your help
spydervx
