Author Topic: Front wiper motor substitute / replacement part  (Read 2091 times)
Offline JASPER_40
  • Country: au
« on: February 19, 2024, 05:01:32 AM »
REF. Series 3 - 1982 Beta coupe with a 5 pin wiper motor connection
Hi,
Has anyone substituted the front wiper motor with something compatible and more affordable than a new or used OEM part ?
Mine wasnt working and upon inspection of the motor, the contacts inside the cover cap are pretty much burnt out and in-turn has overheated causing the "lump" on the "return to park" cam to be also burnt and not functional.
Definitely time for a new one but they are just so incredibly expensive new (160 GBP and then another 50 to ship to me in Australia). I can source a used part but they all look very old and there is no telling if they are as bad as the one that I am replacing. The available used ones are also big money.
Anyway, surely there is an acknowledged substitute part, even after a bit of modification ?
Googling this motor shows up hundreds of motors which all look physically similar.
Cheers.
Steve
« Last Edit: February 19, 2024, 02:07:10 PM by JASPER_40 »
Current project in Aus :
Previously owned in UK:
1984 HPE Volumex
1982 HPE 2000 IE
1979 Coupe 1600
Offline JASPER_40
  • Country: au
Re: Front wiper motor substitute / replacement part
« Reply #1 on: February 19, 2024, 02:09:36 PM »
Also....anyone know the differences are between the 5 pin and 6 pin motor connections.
Both seems to be listed as the correct parts for a Beta
1984 HPE Volumex
1982 HPE 2000 IE
1979 Coupe 1600
