Author Topic: Gasket material  (Read 2061 times)
Gasket material
« on: February 23, 2024, 11:44:36 AM »
I was watching the latest video from M539 Restorations and he gave options on sealing surfaces on the engine he was building. I thought it may give some useful ideas and alternative to using RTV for some applications. I bought a small can of Permatex to use which I will try on the sump of the Spider which needs re-sealing. I originally used RTV with a cork gasket which lasted ok for a couple of years, but given what I know now re loose RTV in the sump and I think it is weeping, needs to be dropped and re-sealed at some point.
Start at 7:30 if you are not interested in the engine build. I would recommend watching at least one of his videos as he is meticulous with them and has some good pointers for amateur engine building with limited tools.
https://youtu.be/XsV0h-9z86c?si=mbA6ESCAER5BCLXB
« Last Edit: February 24, 2024, 01:18:30 PM by peteracs »
Re: Gasket material
« Reply #1 on: February 24, 2024, 08:29:03 AM »
Hi Peter,
Very useful confirming my recent purchase of Loctite 5923 to coat my gaskets on the dreaded Abarth R10 Supercharger outer casing. The small art paint brush was a tool I have not been smart enough to use before!
