Author Topic: Oil sensors and switches  (Read 18308 times)
« on: February 23, 2024, 03:42:24 PM »
Afternoon all, just want to double check a few things as my oil temperature gauge is not working
On my dashboard (pic 2) I have :
6. Engine oil low pressure warning light
7. Oil pressure gauge.
11. Oil temperature gauge.
Around the oil filter (pic 1) I have:
2. Oil pressure transmitter (guessing this links to 7. Oil pressure gauge)
6. Oil pressure switch (guessing this links to 6. Engine oil low pressure warning light)
If that's correct, where is the oil temperature sensor?
Haynes (that font of truth) has the following
Oil Pressure Switch...Blue.
Oil Temperature Sender...Yellow/Black.
Oil Pressure Sender...Grey/Red.
Fairly sure I may have some of these wrong way round :(
Re: Oil sensors and switches
« Reply #1 on: February 23, 2024, 05:46:38 PM »
Hi John
 Nos 12 in you diagram?
« Reply #2 on: February 25, 2024, 01:10:59 PM »
Hi John,
My Lancia diagram shows Yellow (G) from the Oil temp sender all
the way to the dash. This yellow wire goes through at least 2 connectors en-route.
On the dash connector it appears to be the right-hand plug,
and is in 'number 2' position, from which side I'm not sure.
« Reply #3 on: February 26, 2024, 09:23:53 AM »
Hi John
I thought I was going mad when I saw your obvious answer. I took the image from a bigger picture, and to recover some credibility, it shows the oil temp labelled 6 not 12.... but in top right, it's different..
« Reply #4 on: February 26, 2024, 10:04:13 AM »
Nigel, thanks for confirming the colours. Found 2 of mine were swapped  :'(
« Reply #5 on: February 26, 2024, 11:18:03 PM »
Hi John
Interesting the main picture only shows two sensors, wonder what engine that is from?
« Reply #6 on: February 27, 2024, 07:14:17 AM »
Hi Peter,
My S2 Berlina 2000 only has oil pressure warning light and oil pressure gauge on the dashboard. No oil temp.
« Reply #7 on: August 18, 2026, 01:06:01 PM »
I am going to buy a couple gauges for oil temp and pressure.  Initially to confirm the status of the engine, and at some point mount in the stereo slot (I think).  I am going to replace the current senders with new to match the gauges, are all the senders M14x1.5?
« Reply #8 on: August 18, 2026, 10:05:00 PM »
Hi Mark,
As far as I recall, the oil senders are a much smaller size, say M8 but
with a fine thread.
The size you quote is more like the water temp stuff on the head.
Probably best to take one out and measure.
Offline Ics19
« Reply #9 on: August 19, 2026, 12:25:46 AM »
...are all the senders M14x1.5?
Think you'll find this is the case :)  All straight threads (not tapered) and typically use an aluminium washer to seal.  The water temperature sensor and switch are M16 tapered fit.
« Reply #10 on: August 19, 2026, 02:04:10 PM »
I took a punt and ordered it all.  Car isnt here to check for another week.
Thank you Ics19 (sorry dont know your name) and Nigel for comments.
Offline betabuoy
  • Chris Mace
« Reply #11 on: August 20, 2026, 02:56:54 PM »
Hi Mark,
with a fine thread...
I think Nigel is probably correct on this one Mark. I did send you a set of photos and part of a GC email to me describing the faff he had in fitting these: "they needed several adaptors as you can see... Much fun and games with BSP and Metric threads and machining"
I'm sure you'll find a way, but if you're using Racetech you should probably be prepared to drill and tap a few threads.
1967 Morris Minor Traveller
1925 Austin 7 Chummy
1948 Piper Cub Vagabond
Offline Ics19
« Reply #12 on: August 20, 2026, 04:41:40 PM »
Interesting - apologies if I've misunderstood, but I thought it was the fitting size of the three sensor/switch ports in the diagram for 2, 6 & 12 that was in question?  If so, the matching parts are these and pretty sure they're all M14 x 1.5 :
https://353652584127257704.weebly.com/store/p96/Oil_pressure_Sender_Unit.html
https://353652584127257704.weebly.com/store/p94/Oil_Pressure_Warning_Sender_Switch.html
https://353652584127257704.weebly.com/store/p93/Oil_Temp_Sender.html
The parts book codes are 4151997, 4422049 and 82240626 respectively so do tie up.
The size of the fitting on the gauge side does look smaller than the original sensors, hence the adaptor, 1/8" BSP?  Unless you're wanting a higher pressure for advanced warning,  I can't see why an adapter was needed for the switch (the one in bottom of pictures) as there was no need to replace that, so why not just use the same/correct part? You can get at least a couple of different pressure values with the same fitting, as the Montecarlo S1 had a lower than normal type to control the electric fuel pump running.
« Last Edit: August 20, 2026, 09:34:44 PM by Ics19 »
« Reply #13 on: August 20, 2026, 05:15:18 PM »
Thank Chris, and yes I had forgot about that mail.  Sorry :-)  I will figure it out.
« Reply #14 on: August 21, 2026, 07:51:23 AM »
Demon Tweek and Merlin Motorsport sell a lot of thread adaptors to get this done without reaching for the tap and dies.
« Reply #15 on: August 21, 2026, 02:14:24 PM »
I was talking to Merlin actually.  Thanks for the input.  They said go for VDO as the range of senders at differing threads is more comprehensive.
Offline lancialulu
« Reply #16 on: August 21, 2026, 02:19:31 PM »
I just go down to my local hydraulic shop with both bits and they find a suitable adapter.....
