Author Topic: Rear crossmember  (Read 25233 times)
Rear crossmember
« on: June 09, 2024, 02:17:18 PM »
I think the rear crossmember is an overlooked component that is easy to improve if you have access to a welder.
It’s a fairly flimsy open box design that I think should be boxed in like Lancia did on the Delta and Thema.
Seeing as the transverse tie rod links mount centrally it makes the flimsy design vulnerable to twisting under hard cornering. As well as giving the rear suspension a more solid base when cornering I think it can be easily modified to stiffen up the rear chassis a little, a bit like a lower strut brace.
I’ve already made one for my HPE but that is some way off of being driven.
So this week I had to drop the rear crossmember to gain access to the fuel pipes that have started leaking on my VX coupe and whilst I was there I decided it was time to strengthen the crossmember and test my theory.
So this is my freshly painted idea.
Re: Rear crossmember
« Reply #1 on: June 09, 2024, 02:30:56 PM »
As the spare wheel well is only around 20mm above the center of the crossmember so I fabricated a small sturdy bracket that bolts the center of the crossmember to the spare wheel well.
Then bolt it all back up and give it a spin.
As expected car car felt significantly different. The immediate feeling was a bit like some kind of mass-damper had been fitted to the car. It feels more sturdy and better built. I know my car has a good rust free chassis as I’ve been under it for over 30 years (Not continually of course, I do come out for tea and beer) and purchased the car from a customer based on the condition on the chassis.
Then as I drove down the nearby roads admiring this new found sturdiness over speed bumps and pot holes I came across a roundabout.
Tip it in, squeeze the throttle and it digs in like a razorshell. It feels like the car has undergone a small all over upgrade.
All in all, I like it and there’s no downside.
« Last Edit: July 05, 2024, 10:43:29 PM by squiglyzigly »
« Reply #2 on: June 09, 2024, 06:06:22 PM »
Hi again Ian,
Based upon your findings I'm sure I'll be doing something very similar to mine.
I like the additional centre support as well. The HPE probably has a deeper distance
to cover, but that's doable.
Cheers, Nigel
« Reply #3 on: July 04, 2024, 04:59:06 PM »
Spot on Ian
This reminds me of John Followell trying to stop his rear cross member flexing. Which of course they all do.
« Reply #4 on: July 05, 2024, 10:03:28 AM »
I've been following with interest . . . .  :)
I have access to plasma cutter, welder and 4 post lifts etc. courtesy of this place
http://www.thisisyourgarage.com
Only caveat for me is fabricating the extra mount and strengthening brackets.
« Reply #5 on: July 05, 2024, 10:04:13 AM »
Hi chaps,
Since doing this on my VX coupe I have subsequently carried this out on my Berlina.
I decided it was easier to replace the fuel hoses on the Berlina with the crossmember removed so I killed 2 birds with one stone.  It was easy enough to leave all the outer suspension connected (car on axle stands) and remove the 2x long center bolts for the tie rods and drop the crossmember from its 4x outer stud/nuts on the chassis rails.
Before strengthening you can easily flex the crossmember back and fourth by hand whilst still bolted in place. After boxing it in and ‘without’ a center mount to the floor it is rock solid.
The first road test in the Berlina was much the same results as the coupe. Everything just feels more solid.
I’ve had this idea kicking around in my head for decades, just wish I had done it earlier.
Cheers Ian
« Last Edit: July 05, 2024, 10:07:44 AM by squiglyzigly »
« Reply #6 on: July 05, 2024, 02:46:53 PM »
Hi John
May I recommend CAD. That is Cardboard Aided Design. Literally make the bits in cardboard i.e. cereal box with lines drawn for fold or cut. Version 3 seams to work for me most of the time. Those round pressed holes Ian is showing use a press tool you an get from Frost Restorations.
I like the idea the rental facilities and that looks like fun.
« Reply #7 on: July 05, 2024, 03:58:13 PM »
Yep, not too far and the guy is a bit of a classic enthusiast. Of course the on site cafe and pool tables help.
Not been there yet but my brother has with an assortment of cars. Tempted to say, if anyone is up there I might drop in to say hi
« Reply #8 on: July 11, 2024, 05:07:44 PM »
Did you also reinforce where the suspension arms bolt to?
« Reply #9 on: July 14, 2024, 06:48:47 PM »
Hi John,
No I didn’t reinforce the bolt holes. Didn’t see the point as I’ve never seen one cracked or damaged. I don’t believe it’s an overly stressed point that will flex or oval out unless the bolts aren’t done up properly.
I’ve seen plenty of cars that have been jacked up and subsequently the arms have bent, but still no damage.
Inside the crossmember I did weld the spacers in place to make assembly easier. And should the bolts ever seize inside (of course the bolts were reassembled with plenty of grease) it will be easier to remove them with the spacers securely welded.
« Reply #10 on: September 29, 2025, 06:10:08 PM »
I've got the rear crossmember out, cleaned up a bit,
and preparing to do Ian's mod.
First thing I noticed is I have to squeeze it to close a 3mm gap to weld the bolt tubes.
Crazy flexing as noted already.
It'll be a bit different as I have an exhaust heat shield that is secured with 2 M6 bolts
that need access from below. I'm also going to make a floor bracket.
All in all, I don't think it matters much how it's done, the principles will remain.
N
« Reply #11 on: September 30, 2025, 03:37:31 PM »
There has to be a sales opportunity for someone.  I would buy one :-)
Interested to see what yours looks like completed and before it goes in.  Maybe its something I could try in the future myself.
« Reply #12 on: September 30, 2025, 04:05:09 PM »
I look forward to your findings Nigel. All 3 of my Betas now have this crossmember mod although the HPE is some way off of being driven. Personally I feel it’s noticeable and worth the work. I can’t take any credit if you like it as I took the idea from other Lancias around the end of Beta production. Themas and 2wd deltas had the closed in design if I remember correctly.
Enjoy
« Reply #13 on: September 30, 2025, 08:24:44 PM »
If I hadn't read about it here I'd be none the wiser so credit can
be taken Ian!
I've got the tubes welded in.
Now there's some CAD to do.
The sides are nowhere near parallel so it'll take some fettling.
N
« Reply #14 on: September 30, 2025, 09:16:01 PM »
Yes I used the CAD design method also. You have probably noticed I made it with 3 pieces of sheet metal. Would have made life unnecessarily difficult trying to do it in one piece.
Ezee
« Reply #15 on: October 04, 2025, 04:07:03 PM »
It's finished and on the car.
I reinterpreted the plate design, drilled holes where needed for access, and
hopefully have achieved similar results to Ian.
I decided not to tie it to the floor due to various items in the way.
I did find the beam pulled slightly due to the welding effect, but only by around 3mm,
so gentle fettling of the pins and holes fixed that.
The rain has come but clear tomorrow, so 2 last jobs are to tighten
the centre arm bolts with the wheels on the floor, and spray Dynamax inside where
the paint brush couldn't reach.
« Last Edit: October 04, 2025, 04:10:24 PM by Nigel »
