Author Topic: Beta coue -earlyish - heater valve  (Read 6329 times)
« on: August 03, 2024, 12:22:02 PM »
Just in time for Betameeta next weekend, the normally fairly faithful steed has thrown a shoe- all over my shoes actually- as coolant is coming from the heater valve at quite a rate. Happily I was only 3 miles from home when I spotted it so got it back without catastrophe.
I googled the part number and Tanc Barret have something the same number, but different in appearance. Mine is a black plastic IPRA item and the suggested replacement is metal see pics.
Will it do the job before I tear over to Ludlow ( about 90 mins) and waste £89 ?.
Re: Beta coue -earlyish - heater valve
« Reply #1 on: August 03, 2024, 01:16:22 PM »
Hi Mark
These plastic valves have been a frequent fail. I think the part offered is worth a try as they only way to really know is to get it up close and personal with the heater pipes and linkages.
Re: Beta coupe -earlyish - heater valve
« Reply #2 on: August 03, 2024, 01:28:54 PM »
My thoughts too Eric. Shame I found the problem too late to get over there today. I'll see if I can get over there asap next week.
« Reply #3 on: August 03, 2024, 05:37:08 PM »
Hi Mark,
At the very least you'll be able to bypass this issue if you can't find the correct
valve.
« Reply #4 on: August 03, 2024, 08:47:48 PM »
I'd not thought of a work-around Nigel. Good idea.
« Reply #5 on: August 05, 2024, 07:52:44 AM »
At least it looks nice and clean under there...
