Author Topic: Brake disc shields, guards, covers  (Read 4890 times)
Offline Clifford3051
« on: September 05, 2024, 07:11:34 PM »
Hi all
These shields are quietly trusting away on my Spyder.
Doing a search on the forum I can't find any real reference to these.
I am assuming we can't get these anymore so only source is getting from a breaker or has someone found a solution/source for them?
Many thanks
C
Re: Brake disc shields, guards, covers
« Reply #1 on: September 05, 2024, 07:24:22 PM »
You could try Jim in Farnborough who has about a dozen cars he plans to break to build 2 or 3....
07736539234
« Reply #2 on: September 05, 2024, 09:50:19 PM »
Hi Clifford
These are often a pain to find here in the U.K. in decent condition. They are often missing and the retaining bolts rusted into the hub. Finding a pair in decent condition can be a trial…..
Best of luck
« Reply #3 on: September 06, 2024, 09:40:01 PM »
Hi Clifford,
I assume you're referring to the rear axle.
As far as I know, the front axle never had these on UK spec cars.
Having said that, my car, being an AU spec, actually has front shields and I have retained them.
I wonder whether any shields are really necessary on a car that doesn't do much mileage and is
kept off dirt roads.
In short, I wouldn't be too concerned to leave them off.
Offline JASPER_40
  • Country: au
« Reply #4 on: October 14, 2024, 07:09:11 AM »
Hi Clifford,
Just a thought....the rear disc shields on my 1984 coupe would not come off unless I first removed the hub....which will comes at the additional cost of a new bearing.  Some judicious cutting of the shield may enable this to come off.
It could be just my incompetance but I had to remove the shield in order to replace the bushing for the ARB to Hub carrier. I just could not see how to get the shield off without pulling the hub.
Someone please tell me I am wrong ?...if not then replacing the shields could be a job you wish you had never started (Rear hub beraring replacement can be a trial also)
Cheers,
Steve
Current project in Aus :
Previously owned in UK:
1984 HPE Volumex
1982 HPE 2000 IE
1979 Coupe 1600
« Reply #5 on: October 14, 2024, 08:59:58 AM »
That's interesting Steve  :o
