Author Topic: Beta Spyder: Disconnected Electrical Connections in the Boot  (Read 4731 times)
Offline Rpat29
« on: November 16, 2024, 02:26:56 PM »
Can anyone help identify the two unconnected connectors in the photos and what they should be connected to or what they were connected to please?
These are from my 1981 Lancia Beta Spyder which I recently acquired and noticed then not connected to anything.
The connectors are located in the boot on the drivers side
thx
Raj
Re: Beta Spyder: Disconnected Electrical Connections in the Boot
« Reply #1 on: November 16, 2024, 10:30:26 PM »
Raj,
I have a Haynes book with all the wiring diagrams.
If you post the wire colours on each fitting, I may be able
to assist tomorrow.
« Reply #2 on: November 16, 2024, 11:03:39 PM »
Hi Nigel
Haynes may not help as a late Spider?
Did the optional hardtop have a heated screen on the Spider and maybe one is for that?
« Reply #3 on: November 17, 2024, 08:21:36 AM »
1 will be for US Spec Electric Fuel Pump the other US Spec Side Markers. Tape over the open ends and forget about them.
Offline Rpat29
« Reply #4 on: November 26, 2024, 02:26:48 PM »
Thanks Guys
I think you are right that it may be for US versions side lights but my car is UK RHD model.
Maybe they install a generic loom that is adaptable for various versions
« Reply #5 on: November 26, 2024, 09:59:13 PM »
As Peter said, the Haynes book is not necessarily good for later models but I do
have diagrams for post-Haynes era cars, so my offer is still open
if you're interested.
Offline Rpat29
« Reply #6 on: December 02, 2024, 03:35:38 PM »
Thanks Nigel
One connector has black and grey wires and the other has 2xyellow and black wires connected to it. see photos
Offline gjanssen
« Reply #7 on: December 02, 2024, 04:19:27 PM »
Hi,
In my 1985 HPE VX the grey/black goes to the fuel pump under the car, before the fuel tank.
The other one with the 2 yellow/black wires is missing in my HPE.
Kind regards,
Gerrit
« Reply #8 on: December 02, 2024, 09:41:55 PM »
Hi,
Gerrit is correct on the Grey/Black function.
The other connector is Yellow/Black and Black which appears to be for
the front and rear fog lights, bizarrely. It's showing as a link between the two, which may
be done in that way due to the requirement for fogs to work only when on dipped beam.
Both legs come from both switches.
Confused? Your not alone!
Offline Rpat29
« Reply #9 on: December 04, 2024, 04:29:42 PM »
Agree.. Very Confusing.
Mine is an 1981 RHD Beta Spyder but in my original owners manual the wiring schematics are for LHD models.
Maybe they wire all the same , see photo
Can anyone work out which number the two connectors refer to?
« Last Edit: December 04, 2024, 04:32:17 PM by Rpat29 »
« Reply #10 on: December 04, 2024, 08:17:08 PM »
138 is the fuel pump one
Offline gjanssen
« Reply #11 on: December 04, 2024, 09:35:09 PM »
And 140 with two yellow/black and two black wires leads to the side clearance lights.
This wire is only for US versions. So you can ignore it…
Offline Rpat29
« Reply #12 on: December 05, 2024, 02:16:30 PM »
Thanks guys for all your help,, I'll ignore those connectors
