Author Topic: New Aluminium Radiator at a cost....  (Read 14830 times)
« on: March 11, 2025, 10:07:55 AM »
Hi All
Just seen this from a company called Roose in Lincoln, deep pockets required.
https://roosemotorsport.co.uk/lancia-beta-coupe-aluminium-radiator.html
Re: New Aluminium Radiator at a cost....
« Reply #1 on: March 11, 2025, 10:46:59 AM »
« Reply #2 on: March 11, 2025, 04:34:49 PM »
I used these guys
https://www.coolexperts.co.uk/brand/lancia/
Recommended and cheaper
« Reply #3 on: March 11, 2025, 07:33:20 PM »
Same photo I think! I wonder who is actually making them?
« Reply #4 on: July 13, 2025, 11:28:18 AM »
I was thinking of sending my radiator off next month whilst on family holiday for a check and referb, any thoughts and experience on cost v one of these?   Everything like this I look at costs >£500
M
« Reply #5 on: July 13, 2025, 11:47:39 AM »
Very late final series Betas actually had aluminium rads but with plastic ends.
« Reply #6 on: July 13, 2025, 12:03:03 PM »
I think the main issue with the plastic ends is that to recore requires specialist equipment to re attach. If they are not recoring then not sure what they will be doing to refurbish?
« Reply #7 on: July 13, 2025, 12:11:10 PM »
True, for most folk really for road use I think recore of original old style is adequate. I have a nos alloy one in mine much prefer the revised hose layout
I completely forgot to point out that S2FL2 cars have a different radiator layout to earlier cars, I'm guessing that those alloy rads only fit up to 1979
« Last Edit: July 13, 2025, 05:57:28 PM by rossocorsa »
Offline neromoto
  • Country: jp
« Reply #8 on: July 27, 2025, 01:18:09 PM »
I had actually bought this radiator earlier this month.
(https://www.coolexperts.co.uk/product/lancia-beta-coupe-aluminium-uprated-radiator/)
And today I replaced the radiator.
All went well with the replacement.
The position of the drain plug is slightly different from the original, but that is not a problem.
The original electric fan was perfectly positioned.
The hoses were fitted perfectly.
With the radiator replacement work completed, I finally attempted to install the engine torque rod.
At this point, however, I discovered a serious problem.
The torque rod could not be fitted. :'(
The original radiator has a recessed area where it interferes with the torque rod.
However, the radiator I bought does not have that recess.
I cannot modify the radiator now.
Would it be quicker to modify the torque rods?
I should have realised about the rods before I bought the radiator.
Can anyone give me some advice on this?
Masakata
Translated with DeepL.com (free version)
Thema 8.32 S2 1990
Gamma Berlina S1 1978
Gamma Coupe S2 1982
Beta HPE S2 1976
Flaminia Coupe 1960
« Reply #9 on: July 27, 2025, 01:28:52 PM »
I would speak to the suppliers, let them know there is an issue and ask them to rectify it, supplying a new radiator if they can't modify the original one. They advertise it as a direct replacement but obviously it's not quite right. They need to know before they sell too many of them.
Offline neromoto
  • Country: jp
« Reply #10 on: July 29, 2025, 12:44:12 AM »
Thanks for the advice.
I have emailed to the shop.
Thema 8.32 S2 1990
Gamma Coupe S2 1982
Beta HPE S2 1976
Flaminia Coupe 1960
Offline neromoto
  • Country: jp
« Reply #11 on: July 29, 2025, 03:01:58 PM »
Here are some of the responses
<<I have made about 7 of these and have not seen this problem before. It almost looks like the radiator has been dented to get the bar to pass over it. I have checked our pattern and this dent is not in it. Also the picture shown on our website does show this model or modification. >>
Did the rods not interfere with the radiator on the Beta with this radiator fitted?
I wonder it.
Masataka
Thema 8.32 S2 1990
Gamma Coupe S2 1982
Beta HPE S2 1976
Flaminia Coupe 1960
« Reply #12 on: July 29, 2025, 03:30:07 PM »
In the parts book it clearly shows the indentation on the radiator. Whilst this is not infallible the pictures are usually fairly reliable. This is the same across the first three series, at least in the parts book, the forth series is a completely different radiator layout. The only differences I can see are that the narrow pipe to the expansion tank seems to have been relocated on later cars than first series.
« Last Edit: July 29, 2025, 03:42:19 PM by rossocorsa »
« Reply #13 on: July 29, 2025, 05:26:42 PM »
They should be making these with the dent as per the original. By warming the aluminum it should be fairly simple to create the dent with the right size round bar, but having skill and experience of this kind of work is advisable. Other wise you can alter the stay rod mountings or add a curved section to the rod.
Offline neromoto
  • Country: jp
« Reply #14 on: July 30, 2025, 01:06:51 AM »
I think it is easiest and cheapest to modify the rods too.
Thema 8.32 S2 1990
Gamma Coupe S2 1982
Beta HPE S2 1976
Flaminia Coupe 1960
« Reply #15 on: July 30, 2025, 11:08:02 AM »
I wonder it.
Masataka
That's a terrible response from someone that states on their website 'Direct fit no alterations necessary.'  I don't doubt that designs changed during production and the angle of that bar on 1.6 & 2.0 will be different but that's not an excuse. I would be sending them that picture from the parts book.
« Reply #16 on: July 30, 2025, 11:42:30 AM »
The problem with Betas, and probably many other cars, is that there are often subtle differences that aren't obvious. Just because something that looks this same fits one version doesn't mean it'll fit another. I've learnt by experience but still make mistakes!
« Reply #17 on: July 30, 2025, 11:50:41 AM »
At some point in the future, when the engine is installed I'll be trial fitting the original radiator before spending cash on a recore (if necessary) but this was the fallback option for me. I've checked my radiator and it doesn't have the scalloped indentation. I can't comment on fitment with the steady bar yet as the car arrived with the cylinder head in the boot... My car is a 1981 2.0 if that helps? I know there's a difference in exhausts so are the cylinder heads taller on the 2 litre cars meaning the clearance is greater and removing the need for this scallop?
« Reply #18 on: July 30, 2025, 11:56:14 AM »
I believe it's the block that's taller but of course that makes the whole engine above the block taller and hence the different bonnet. I have a vague recollection that I've seen a steady rod with a curve at one end but could be imagining it, beta variations can make your brain go crazy!
« Reply #19 on: July 30, 2025, 12:29:15 PM »
The difference in height was the block, the heads are all very similar (see GCs book if you have one available to view).
On the later cars (ones with the later grill and bonnet hinges?) the radiator fitment was different, not sure if your car has this style rad or if the clearance of the steady bar is any more?
