Author Topic: SA Import Beta 2000 Coupe  (Read 71547 times)
0 Members and 5 Guests are viewing this topic.
Re: SA Import Beta 2000 Coupe
« Reply #420 on: April 07, 2026, 10:57:16 AM »
You can buy those Recaro Elastic Straps, but I have lost the details. After 40 years the elastic is past its best and easy enough to change it.
« Reply #421 on: April 08, 2026, 12:31:06 PM »
I will take a look, I am also missing a side release button, its slightly different than whats seems to be availible in Internet world
Changed the jets today and so much better, plugs are here later.  I feel so much happier to drive it now.  Dyno/tune next week should really sort it
Merc EQA
« Reply #422 on: April 08, 2026, 06:52:04 PM »
I was also missing one side tilt button.
Ended up finding one on ebay for around £30. Extortion, but needs must.
Capri's of similar vintage have the same buttons.
N
« Reply #423 on: April 08, 2026, 10:49:46 PM »
I will bear in mind, and keep looking.  I have the interior, cards mostly, but I need to find a donor set.
New Champion N7YC plugs from these guys, very recommended.  https://www.gsparkplug.com/1x-champion-spark-plug-n7yc.html
OMG plugs and jets what a difference, even cold'ish on no choke it was ticking over at way too low revs and the timing was nice and static.
https://youtube.com/shorts/dfvTMwgMbIA?si=fzYLDamH2oH4-5D9
Even the old grotty plugs were better after the 10 min drive earlier.  Out for run tomorrow after work hopefully.
Merc EQA
« Reply #424 on: April 12, 2026, 10:19:43 AM »
So yesterday me and my son Tom drove the 80 miles there and back to The Departure Lounge Italian Day.  Car preformed faultlessly, A3, 55-70, but mostly under 60mph.  Met a fellow Beta Appreciation FB page Vx owner Lloyd W and had a good old chat.  On the way home stopped off to see a mates 1935 Lagonda.
So the good: it didnt catch fire or blow up, my quick and dirty car phone mount worked, it steered straight, the brakes worked well.  Gears I am thinking I just need more practice.
The not so good/needs work: I dont thing suspension wise its all good.  Back looks too high.  I will do some measuring later.  I dont like the front wishbone bushes so have a set of OEM looking ones from Ricambio International.  I think first is the front bushes, maybe get it all tracked and see if the rear end settles down or look at maybe some Vx springs Mark said he had.  Back to the bushes...
I never had OEM bushes fitted when I got the car.  I had home made and cracked ptfe bushes.  If I put std items back in I am missing the ring that I assume is a spacer so you get the right bush location?  Anyone out there have one you could measure for me and I will get something made?
Suspension/handling: what can I check?  Tyre pressures, ride height, tracking/setup, front bushes, anything else?
PS phone holder quick and dirty mount worked a treat.  Thanks Eric
Merc EQA
« Reply #425 on: April 12, 2026, 10:24:31 AM »
I've got a set of nice shiny plated front bush steel rings for you Mark. I just chucked them in with a load of stuff to be plated and then found out you don't need them with Mark's Polybush kit!
Now if only I can find your address again....
« Reply #426 on: April 12, 2026, 10:25:48 AM »
I am trying to resize an image of the collar for the front bushes I am looking for but for the life of me I cant upload...
Basically its a spacing collar I think on the front bush, it has dimples I am thinking stop it moving about.
https://lanciabeta.co.uk/forum/index.php?topic=2575.0
one last try
Merc EQA
« Reply #427 on: April 12, 2026, 10:29:06 AM »
just sent an email to you Guy
Merc EQA
« Reply #428 on: April 12, 2026, 12:34:38 PM »
Two hours searching and no sign of them.....
Sorry Mark, I have a feeling that they were amongst some parts I took down to Mark Wastnidge last year, parts I knew I wouldn't be using but that might find a useful home somewhere. They must have been with that lot. He may have put them somewhere himself? Worth a call.
Sorry!
Offline lancialulu
« Reply #429 on: April 12, 2026, 12:39:45 PM »
Guy, I have just fitted MW's poly bush to wishbone with spacers. Why do you say you dont need them?
« Reply #430 on: April 12, 2026, 12:59:26 PM »
Mine wouldn't fit Tim. The rings compressed the bush and distorted either the bush or the ring itself. The poly bush shoulder is wider than the ring and sits on the outer surface of the wishbone too. Of course it's possible I've got this wrong....
« Reply #431 on: April 12, 2026, 01:08:50 PM »
Hi Tim, I also note that there are two types of front PolyBush on Mark's website.
There's one that uses the original bushing's sleeve and spacer in the wishbone. This is a one part bush. If you check out the photos of this bush on the website it retains the spacer collar and outer sleeve. Is that what you have?
There's also kit which requires the removal of the sleeve and has two parts which is what I have on my car.
Offline lancialulu
« Reply #432 on: April 12, 2026, 09:25:17 PM »
I think I bought these or something like them
https://www.ricambio.co.uk/products/front-lower-control-arm-bush-lancia-beta
« Reply #433 on: April 13, 2026, 12:02:37 AM »
That's the standard bush Tim, you'd need the spacer ring with them.
These are the ones I bought
https://353652584127257704.weebly.com/store/p153/PU_Front_Lower_Wishbone_Set.html
And this is the replacement that keeps the outer sleeve and the spacer ring
https://353652584127257704.weebly.com/store/p599/New_PU_Wishbone_Bush.html
Offline lancialulu
« Reply #434 on: April 13, 2026, 10:28:11 AM »
Maybe I didnt buy MW polybushes after all.....
« Reply #435 on: April 13, 2026, 06:28:41 PM »
[gulp...]
Dyno here we come.  If he gets to hoof it on the rolling road I will take that as a win
Merc EQA
« Reply #436 on: April 13, 2026, 06:30:26 PM »
ride height is exactly as Mark's spring mule on std OEM springs - 375'ish at the front and 365 at the back centre to wheel arch lip.  Still looks high to me on the back...
Merc EQA
« Reply #437 on: April 15, 2026, 10:58:14 AM »
First report back is 105 bhp and really really rich, plus there is something blocked in the carb.  Investigation continues.
Merc EQA
« Reply #438 on: April 15, 2026, 12:28:47 PM »
It sounds like you have good people on the job. With your bigger valves, higher comp pistons and better than standard cams. I think you will get to 120+ with that carb sorted out and the standard exhaust once they have fixed the issues. I assume you are using 99 octane fuel. The original figures did many years ago. If you come away with great throttle response and decent economy do not worry over the end BHP.
« Reply #439 on: April 15, 2026, 02:13:07 PM »
Thanks Eric, yes agree.  The fact it can do a dyno session is a major start.  It felt fast enough on the last couple runs, or maybe thats the noise (please see other thread going on   :o )
Headlights, front bushes and maybe vx springs next
Merc EQA
