Author Topic: Another Which Pump Question  (Read 4498 times)
« on: June 19, 2025, 08:36:41 PM »
The pump that's been recommended on other threads is a Huco one, mounted in the engine bay, relay controlled etc etc. Whilst this is obviously fine for the DATR carburettor will it be able to cope with a pair of Twin 40 dell'Orto carbs or should I be looking at something else?
Re: Another Which Pump Question
« Reply #1 on: June 19, 2025, 09:13:40 PM »
Guy,
I would pose that question to Fast Road Cars who probably
know more about that pump.
« Reply #2 on: June 20, 2025, 12:19:12 PM »
The Huco pumps are very low pressure  - 4.5psi for the tamk mounted 2.2psi for the underbonnet ones. That's a bit marginal by the time it gets to the carb.  It's not recommended to use a tank mount one under the bonnet as they have very little draw.
« Reply #3 on: June 20, 2025, 04:36:27 PM »
Thanks Nigel. Recommendation is for a Facet Silver Top and an 85mm Filter King.
Time will tell if it’s right or not!
« Reply #4 on: June 20, 2025, 10:27:02 PM »
I don't know whether it was my poor installation or a bad pump,
but I fitted a Facet initially (not sure of type) and found it very noisy.
If I ever need to re-visit the pump, I'll probably go
for an in-line barrel-shaped Bosch type unit, similar to what's fitted
at the factory on ie/vx versions.
