Author Topic: Confusion over second dizzy  (Read 10160 times)
Offline deks
  • Steve Hudson
Re: Confusion over second dizzy
« Reply #20 on: September 29, 2025, 03:38:42 PM »
Hi Steve
The 4 bolts/studs are for an exhaust support on the normal exhaust
Hi Peter. Many thanks for that learning each and every day
Offline deks
  • Steve Hudson
« Reply #21 on: September 29, 2025, 03:42:19 PM »
So two things re engine
First I can find the engine number that should be stamped on the block somewhere  possibly I am looking in the wrong place but Ill worry about that later
Second thing is the engine block code which I have found  28CB1 A O Lancia   on the block seems to relate to a VX engine so it looks like it's not just the head thats been changed which would make sense to be fair easier to just drop a complete engine in  Again not worried by this.
« Reply #22 on: September 29, 2025, 05:02:38 PM »
The engine code is stamped just above the oil filter housing, should start 828, though can be hard to see some of the numbers sometimes.
I would be surprised if this was a VX engine given how few of them there were in the UK and how many more of the IE there was. Also the head is consistent with a late 2L non VX as the VX has a different head casting by having larger inlet valves.
Offline deks
  • Steve Hudson
« Reply #23 on: September 29, 2025, 05:14:18 PM »
Hi Peter  yes found engine code as for type this is yet for me to learn  the same article that i found i google also mention I.E  the differences is something I know nothing about so you may well be correct in your comments  (y)
« Reply #24 on: September 30, 2025, 12:45:56 PM »
I'm not sure I've seen one before with the pump mounting removed at casting  - but then all of mine have been earlier. I wonder if it's still got the annoying lobe on the auxilairy shaft ?
I think that my VX block has the fuel pump mount cast over, but I'll try to remember to check when I can, they probably started doing it at some point for both VX and ie. Still has the lobe but it can be cut off and plugged.
« Last Edit: September 30, 2025, 10:55:44 PM by rossocorsa »
Online SanRemo78
« Reply #25 on: September 30, 2025, 10:52:18 PM »
If it were a VX engine I’m sure it would have had work done to increase the compression ratio! Most likely a late IE.
Offline deks
  • Steve Hudson
« Reply #26 on: October 01, 2025, 07:48:50 AM »
As I said to Peter. I still have to learn what engine is what. it was just what came up on google. Dont really know what the VX or the IE engines are.
I assume the engine in mine is from a later car with fuel injection based on what has been said with the injection system removed and a car fitted.
at first thought it was just the head that was different but it seems its the whole engine which would make some sense if fitting a second hand one in it
not sure if there are any power differences or advantage/disadvantage to this but there isnt much I can do about it either way ;D :)
